[postgis-tickets] [PostGIS] #3480: ST_ClusterDBSCAN get ptarray_contains_point called on unclosed ring
    trac at osgeo.org
    Sat Feb 27 08:38:33 PST 2016
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  high     |  Milestone:  PostGIS 2.3.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 I don't think this is an expected result.
 -- fake parcels produces 12 rows valid polygons
 DROP TABLE IF EXISTS parcels ;
 CREATE TABLE parcels AS
 SELECT row_number() OVER() AS parcel_id,
     ST_Subdivide(ST_Buffer('LINESTRING(50 100, 98 100, 100
 150)'::geometry,40, 'endcap=square'),8) As geom;
 -- gives error
 SELECT ST_ClusterDBSCAN(geom,0.2,5) over () AS cid, geom
 FROM parcels;
 ERROR:  ptarray_contains_point called on unclosed ring
 ********** Error **********
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3480>
