[postgis-tickets] [PostGIS] #3479: ST_ClusterKMeans hangs with one row
PostGIS trac at osgeo.org
Mon Feb 29 05:45:46 PST 2016
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  reopened
  Priority:  blocker  |  Milestone:  PostGIS 2.3.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 Okay it just crashes, does 1 work on your machine.  Maybe now it's a
 windows issue.
 POSTGIS="2.3.0dev r14719" GEOS="3.5.0-CAPI-1.9.0 r4090" SFCGAL="1.2.2"
 PROJ="Rel. 4.9.1, 04 March 2015" GDAL="GDAL 2.0.1, released 2015/09/15"
 LIBXML="2.7.8" LIBJSON="0.12" RASTER PostgreSQL 9.5.1, compiled by Visual
 C++ build 1800, 64-bit
 SELECT ST_ClusterKMeans(geom,1) over () AS cid, geom
 FROM parcels;
 crashes back end
 This might be the same issue as #3481
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3479#comment:6>
