[postgis-tickets] [PostGIS] #3483: Problem with ST_Union
trac at osgeo.org
Mon Feb 29 07:35:37 PST 2016
Reporter: krzysiek | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.9
Component: postgis | Version: 2.1.x
Keywords: ST_Union, raster, alignment |
I have loaded some rasters into Postgis. I did a lot of ST_XXXX (scale,
snap to grid,resample) magic to make them aligned. After executing:
select
r1.rid,r2.rid
,ST_NotSameAlignmentReason(r1.rast,r2.rast)
,ST_SameAlignment(r1.rast,r2.rast)
from
rasters.r r1,
rasters.r r2
where not ST_SameAlignment(r1.rast,r2.rast)
I got nothing, if I remove:
all I got is
"The rasters are aligned"
Which seems ok, but when I execute:
SELECT ST_Union(rast,'FIRST') from rasters.r
I got:
rt_raster_from_two_rasters: The two rasters provided do not have the
same alignment
Why ?
Postgres 9.4
"POSTGIS="2.1.8 r13780" GEOS="3.5.0-CAPI-1.9.0 r4090" PROJ="Rel. 4.8.0, 6
March 2012" GDAL="GDAL 1.11.1, released 2014/09/24" LIBXML="2.7.8"
LIBJSON="UNKNOWN" RASTER"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3483>
