[postgis-tickets] [PostGIS] #3444: Add dump/restore testing
PostGIS trac at osgeo.org
Mon Feb 29 09:22:21 PST 2016
  Reporter:  strk         |      Owner:  robe
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 2.3.0
 Component:  buildbots    |    Version:  2.2.x
Resolution:               |   Keywords:
Comment (by strk):
 --dumprestore simply adds a pg_dump and a pg_restore step
 to the initialization phase, so should work both with extension
 and with script.
 The only difference is that when restoring with extension you
 cannot guarantee what version will be restored, because
 the dump will contain a "CREATE EXTENSION postgis" with no
 version specification, so the outcome will depend on what's
 the default postgis version according to postgis.control.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3444#comment:23>
