[postgis-tickets] r14721 - Try to fix make install issue using --prefix
Regina Obe lr at pcorp.us
Mon Feb 29 09:38:48 PST 2016
Author: robe
Date: 2016-02-29 09:38:48 -0800 (Mon, 29 Feb 2016)
New Revision: 14721
   trunk/ci/debbie/postgis_regress.sh
references #2688
Modified: trunk/ci/debbie/postgis_regress.sh
--- trunk/ci/debbie/postgis_regress.sh	2016-02-29 13:14:29 UTC (rev 14720)
+++ trunk/ci/debbie/postgis_regress.sh	2016-02-29 17:38:48 UTC (rev 14721)
@@ -53,7 +53,9 @@
 ./configure \
     --with-pgconfig=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}/bin/pg_config \
     --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/geos-config \
-    --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin/gdal-config --with-sfcgal=/usr/bin/sfcgal-config --without-interrupt-tests
+    --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin/gdal-config --with-sfcgal=/usr/bin/sfcgal-config \
+    --without-interrupt-tests \
+    --prefix=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}
 make clean
 ## install so we can later test extension upgrade
 make
