[postgis-tickets] [PostGIS] #3416: topology: crash when loading topogeometry (regression)
trac at osgeo.org
Mon Jan 4 02:35:37 PST 2016
Reporter: rulus | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.1
Component: postgis | Version: 2.2.x
Keywords: |
Recent versions of the 2.2 branch fail to load (some?) topogeometries;
using the toTopoGeom function leads to a database crash.
Using gdb I got this backtrace:
Program received signal SIGSEGV, Segmentation fault.
_box2d_to_hexwkb (bbox=bbox at entry=0x99, srid=31370) at
postgis_topology.c:126
126 p.x = bbox->xmin;
(gdb) bt
#0 _box2d_to_hexwkb (bbox=bbox at entry=0x99, srid=31370) at
#1 0x00007efe26269757 in cb_getEdgeByFace (topo=0x55e7c0fa68d0,
ids=0x7ffd4e19c098, numelems=0x7ffd4e19c0a4, fields=153, box=0x99) at
postgis_topology.c:914
#2 0x00007efe2792f115 in ?? () from /usr/lib/liblwgeom-2.2.so.2
#3 0x00007efe279307bf in ?? () from /usr/lib/liblwgeom-2.2.so.2
#4 0x00007efe27935e88 in lwt_AddLine () from /usr/lib/liblwgeom-2.2.so.2
#5 0x00007efe27936642 in lwt_AddPolygon () from
#6 0x00007efe2626fbc5 in TopoGeo_AddPolygon (fcinfo=0x55e7c0f9f7e0) at
postgis_topology.c:4426
#7 0x000055e7c022e496 in ?? ()
#8 0x000055e7c0230e6d in ExecProject ()
#9 0x000055e7c0243568 in ExecResult ()
#10 0x000055e7c0229d18 in ExecProcNode ()
#11 0x000055e7c0226f5e in standard_ExecutorRun ()
#12 0x000055e7c0321247 in ?? ()
#13 0x000055e7c0322bc0 in PortalRunFetch ()
#14 0x000055e7c024b6bd in ?? ()
#15 0x00007efe3b597b6b in ?? () from
/usr/lib/postgresql/9.4/lib/plpgsql.so
#16 0x00007efe3b5943f3 in ?? () from
#17 0x00007efe3b597bf1 in ?? () from
#18 0x00007efe3b5943f3 in ?? () from
#19 0x00007efe3b596aad in ?? () from
#20 0x00007efe3b596cd2 in plpgsql_exec_function () from
#21 0x00007efe3b58bd49 in plpgsql_call_handler () from
#22 0x000055e7c022ae83 in ?? ()
#23 0x00007efe3b590cb4 in ?? () from
#24 0x00007efe3b5922c9 in ?? () from
#25 0x00007efe3b594731 in ?? () from
#26 0x00007efe3b596aad in ?? () from
#27 0x00007efe3b596cd2 in plpgsql_exec_function () from
#28 0x00007efe3b58bd49 in plpgsql_call_handler () from
#29 0x000055e7c022ae83 in ?? ()
#30 0x000055e7c0230e6d in ExecProject ()
#31 0x000055e7c0231281 in ExecScan ()
#32 0x000055e7c0229cc8 in ExecProcNode ()
#33 0x000055e7c0231228 in ExecScan ()
#34 0x000055e7c0229c78 in ExecProcNode ()
#35 0x000055e7c02409b9 in ExecModifyTable ()
#36 0x000055e7c0229d08 in ExecProcNode ()
#37 0x000055e7c0226f5e in standard_ExecutorRun ()
#38 0x000055e7c03218c8 in ?? ()
#39 0x000055e7c0321b00 in ?? ()
#40 0x000055e7c0322734 in PortalRun ()
#41 0x000055e7c031f4e3 in PostgresMain ()
#42 0x000055e7c00e8773 in ?? ()
#43 0x000055e7c02c950a in PostmasterMain ()
#44 0x000055e7c00e990c in main ()
The issue is introduced in r14226 (found using git bisect), which relates
to ticket #3321.
Last working version in the 2.2 branch is: PostgreSQL 9.4.5 on x86_64
-unknown-linux-gnu, compiled by gcc (Debian 5.2.1-23) 5.2.1 20151028,
64-bit "POSTGIS="2.2.1dev r14218" GEOS="3.5.0-CAPI-1.9.0 r4084" PROJ="Rel.
4.9.2, 08 September 2015" GDAL="GDAL 2.0.1, released 2015/09/15"
LIBXML="2.9.3" LIBJSON="0.11.99" TOPOLOGY RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3416>
