[postgis-tickets] r14548 - Provide example of micro/macro variant address_standardizer
Regina Obe
lr at pcorp.us
Mon Jan 4 11:52:21 PST 2016
Author: robe
Date: 2016-01-04 11:52:21 -0800 (Mon, 04 Jan 2016)
New Revision: 14548
trunk/doc/extras_address_standardizer.xml
Closes #3353 for 2.3
Modified: trunk/doc/extras_address_standardizer.xml
--- trunk/doc/extras_address_standardizer.xml 2016-01-04 19:30:05 UTC (rev 14547)
+++ trunk/doc/extras_address_standardizer.xml 2016-01-04 19:52:21 UTC (rev 14548)
@@ -645,6 +645,9 @@
<title>Description</title>
<para>Returns an <xref linkend="stdaddr" /> form of an input address utilizing <xref linkend="lextab" /> table name, <xref linkend="gaztab" />, and <xref linkend="rulestab" /> table names and an address.</para>
+ <para>Variant 1: Takes an address as a single line.</para>
+ <para>Variant 2: Takes an address as 2 parts. A <varname>micro</varname> consisting of standard first line of postal address e.g. <code>house_num street</code>, and a macro consisting of standard postal second line of an address e.g <code>city, state postal_code country</code>.</para>
<!-- use this format if new function -->
<para>Availability: 2.2.0</para>
@@ -655,9 +658,11 @@
<refsection>
<title>Examples</title>
<para>Using address_standardizer_data_us extension</para>
- <programlisting>CREATE EXTENSION address_standardizer_data_us; -- only needs to be done once
-SELECT house_num, name, suftype, city, country, state, unit FROM standardize_address('us_lex',
- 'us_gaz', 'us_rules', 'One Devonshire Place, PH 301, Boston, MA 02109-1234');</programlisting>
+ <programlisting>CREATE EXTENSION address_standardizer_data_us; -- only needs to be done once</programlisting>
+<para>Variant 1: Single line address. This doesn't work well with non-US addresses</para>
+<programlisting>SELECT house_num, name, suftype, city, country, state, unit FROM standardize_address('us_lex',
+ 'us_gaz', 'us_rules', 'One Devonshire Place, PH 301, Boston, MA 02109');</programlisting>
<screen>house_num | name | suftype | city | country | state | unit
1 | DEVONSHIRE | PLACE | BOSTON | USA | MASSACHUSETTS | # PENTHOUSE 301</screen>
@@ -668,7 +673,7 @@
<para>Make easier to read we'll dump output using hstore extension CREATE EXTENSION hstore; you need to install</para>
<programlisting>SELECT (each(hstore(p))).*
FROM standardize_address('tiger.pagc_lex', 'tiger.pagc_gaz',
- 'tiger.pagc_rules', 'One Devonshire Place, PH 301, Boston, MA 02109-1234') As p;</programlisting>
+ 'tiger.pagc_rules', 'One Devonshire Place, PH 301, Boston, MA 02109') As p;</programlisting>
<screen> key | value
box |
@@ -689,6 +694,31 @@
ruralroute |
(16 rows)
</screen>
+<para>Variant 2: As a two part Address</para>
+<programlisting>SELECT (each(hstore(p))).*
+ FROM standardize_address('tiger.pagc_lex', 'tiger.pagc_gaz',
+ 'tiger.pagc_rules', 'One Devonshire Place, PH 301', 'Boston, MA 02109, US') As p;</programlisting>
+<screen> key | value
+ box |
+ city | BOSTON
+ name | DEVONSHIRE
+ qual |
+ unit | # PENTHOUSE 301
+ extra |
+ state | MA
+ predir |
+ sufdir |
+ country | USA
+ pretype |
+ suftype | PL
+ building |
+ postcode | 02109
+ house_num | 1
+ ruralroute |
+(16 rows)</screen>
</refsection>
<!-- Optionally add a "See Also" section -->
