[postgis-tickets] [PostGIS] #3401: ST_ModEdgeSplit makes topology invalid
trac at osgeo.org
Tue Jan 5 03:27:31 PST 2016
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.1
Component: topology | Version: trunk
Resolution: | Keywords: 32bit
Comment (by strk):
In other words, a point contained in a line does not yeld itself when its
location is interpolated on the line:
$ with inp as ( SELECT 'LINESTRING(-180 0,0 0)'::geometry a, 'POINT(-20
0)'::geometry b ),
op as ( select a, b, ST_LineInterpolatePoint(a,ST_LineLocatePoint(a,b)) rt
from inp )
select ST_AsText(a) a, ST_AsText(b) b, ST_AsText(rt), ST_Distance(b, rt),
ST_Equals(b, rt) from op;
-[ RECORD 1 ]-----------------------
a | LINESTRING(-180 0,0 0)
b | POINT(-20 0)
st_astext | POINT(-20 0)
st_distance | 7.105427357601e-15
st_equals | f
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3401#comment:16>
