[postgis-tickets] [PostGIS] #3417: parse_address add example of using with a table of addresses
trac at osgeo.org
Tue Jan 5 08:21:41 PST 2016
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.0
Component: documentation | Version: 2.2.x
Keywords: |
Someone mentioned this on IRC:
thread here. I realized that's probably more common use that the example
we have in docs, so needs to be added.
<ElizabethAB> I have what I expect to be a simple question. I have a table
with an address string, say `table1` with variable `address`. The examples
for the `parse_address()` function show passing directly a string,
http://postgis.net/docs/parse_address.html. How do I instead pass the
variable from the table?
<robe2> ElizabethAB: SELECT (a).* FROM (SELECT parse_address(address) As
a FROM table1) As foo;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3417>
