[postgis-tickets] [PostGIS] #3418: KNN recheck in 9.5 fails with index returned tuples in wrong order when used in function
PostGIS trac at osgeo.org
Tue Jan 5 21:19:50 PST 2016
used in function
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.2.2
 Component:  postgis  |    Version:  2.2.x
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> As Stephen Mathers noted on the list, he was able to break our precious
> KNN recheck code.  I'm hoping this is something we can push upstream.
> Will try to replicate with build in PostgreSQL geometry types.
> -- to replicate
> DROP TABLE knn_recheck_geom IF EXISTS;
> CREATE TABLE knn_recheck_geom(gid serial primary key, geom geometry);
> INSERT INTO knn_recheck_geom(gid,geom)
> SELECT ROW_NUMBER() OVER(ORDER BY x,y) AS gid, ST_Point(x*0.777,y*0.887)
> As geom
> FROM generate_series(-100,1000, 9) AS x CROSS JOIN
> generate_series(-300,1000,9) As y;
> CREATE OR REPLACE FUNCTION zz_2nn_angle(geometry) RETURNS float AS $$
> -- Here are my wonderful points to KNN search:
> WITH index_query AS (
>         SELECT edge.geom AS geom
>         FROM (SELECT * FROM knn_recheck_geom) AS edge
> -- This is my query point
>         ORDER BY $1
>         edge.geom LIMIT 2
> templine AS (
>         SELECT ST_MakeLine(geom) AS geom FROM index_query
> angle1 AS (
>         SELECT ST_Azimuth(ST_StartPoint(geom), $1) angle FROM templine
> angle2 AS (
>         SELECT ST_Azimuth(ST_EndPoint(geom), $1) angle FROM templine
> SELECT a1.angle - a2.angle FROM angle1 a1, angle2 a2
> $$ LANGUAGE SQL;
> CREATE INDEX idx_knn_recheck_geom on knn_recheck_geom using gist(geom);
> WITH returnline AS (
>         SELECT gid, geom,
>                 zz_1nn_d(geom) AS distance,
>                 abs(degrees(zz_2nn_angle(geom))) AS angle FROM
>                 (SELECT * FROM knn_recheck_geom) subset
> SELECT * FROM returnline;
> Returns:
> ERROR:  index returned tuples in wrong order
> CONTEXT:  SQL function "zz_2nn_angle" statement 1
> ********** Error **********
New description:
 As Stephen Mathers noted on the list, https://lists.osgeo.org/pipermail
 /postgis-devel/2016-January/025559.html
 he was able to break our precious KNN recheck code.  I'm hoping this is
 something we can push upstream. Will try to replicate with build in
 -- to replicate
 As geom
         ORDER BY $1
         edge.geom LIMIT 2
 templine AS (
 angle1 AS (
 angle2 AS (
 $$ LANGUAGE SQL;
         SELECT gid, geom,
 Returns:
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3418#comment:1>
