[postgis-tickets] r14563 - Add 2.2.1 section in NEWS file
Sandro Santilli
strk at keybit.net
Wed Jan 6 02:27:39 PST 2016
Author: strk
Date: 2016-01-06 02:27:39 -0800 (Wed, 06 Jan 2016)
New Revision: 14563
trunk/NEWS
Modified: trunk/NEWS
--- trunk/NEWS 2016-01-06 10:25:59 UTC (rev 14562)
+++ trunk/NEWS 2016-01-06 10:27:39 UTC (rev 14563)
@@ -12,6 +12,40 @@
- #2259 ST_Voronoi (Dan Baston)
- #3339 ST_GeneratePoints (Paul Ramsey)
+PostGIS 2.2.1
+2016/01/06
+ * Bug Fixes *
+ - #2232, avoid accumulated error in SVG rounding
+ - #3321, Fix performance regression in topology loading
+ - #3329, Fix robustness regression in TopoGeo_addPoint
+ - #3349, Fix installation path of postgis_topology scripts
+ - #3351, set endnodes isolation on ST_RemoveIsoEdge
+ (and lwt_RemIsoEdge)
+ - #3355, geography ST_Segmentize has geometry bbox
+ - #3359, Fix toTopoGeom loss of low-id primitives from
+ TopoGeometry definition
+ - #3360, _raster_constraint_info_scale invalid input syntax
+ - #3375, crash in repeated point removal for collection(point)
+ - #3378, Fix handling of hierarchical TopoGeometries
+ in presence of multiple topologies
+ - #3380, #3402, Decimate lines on topology load
+ - #3388, #3410, Fix missing end-points in ST_Removepoints
+ - #3389, Buffer overflow in lwgeom_to_geojson
+ - #3390, Compilation under Alpine Linux 3.2 gives an error when
+ compiling the postgis and postgis_topology extensions
+ - #3393, ST_Area NaN for some polygons
+ - #3401, Improve ST_Split robustness on 32bit systems
+ - #3404, ST_ClusterWithin crashes backend
+ - #3407, Fix crash on splitting a face or an edge
+ defining multiple TopoGeometry objects
+ - #3411, Clustering functions not using spatial index
+ - #3412, Improve robustness of snapping step in TopoGeo_addLinestring
+ - #3415, Fix OSX 10.9 build under pkgsrc
+ - Fix memory leak in lwt_ChangeEdgeGeom [liblwgeom]
PostGIS 2.2.0
2015/10/07
