[postgis-tickets] r14585 - update 2.2.1 release details
Regina Obe
lr at pcorp.us
Mon Jan 11 00:46:27 PST 2016
Author: robe
Date: 2016-01-11 00:46:26 -0800 (Mon, 11 Jan 2016)
New Revision: 14585
web/_content/pages/windows_downloads.html
Modified: web/_content/pages/windows_downloads.html
--- web/_content/pages/windows_downloads.html 2016-01-07 18:02:37 UTC (rev 14584)
+++ web/_content/pages/windows_downloads.html 2016-01-11 08:46:26 UTC (rev 14585)
@@ -12,29 +12,25 @@
# Released Versions
-PostGIS 2.2.1 came out January 6th, 2015. Binaries currently available in experimental section. Application stackbuilder installers will be coming soon.
+PostGIS 2.2.1 came out January 6th, 2015. Binaries currently available in experimental section. Installers available on Application Stackbuilder for PostgreSQL 9.5 32/64-bit.
+Others coming this soon.
-PostGIS 2.2.0 came out October 7th, 2015.
-PostgreSQL 9.5beta2 (64-bit rereleased November 21st 2015 recompiled against 9.5beta2) 9.5beta2 32-bit (released Nov 21st 2015), 9.4 (32/64-bit), 9.3 (64-bit,32-bit) 2.2.0 is now available on application stackbuilder and postgis downloads site
-**If you installed PostGIS 2.2.0 for PostgreSQL 9.5beta1x64, you may want to reinstall after upgrading to PostgreSQL 9.5beta2x64 particularly if you use OGRFDW or SFCGAL.
-The PostgreSQL 9.5beta1 PostGIS bundle OGRFDW is incompatible with PostgreSQL 9.5beta2 and the SFCGAL bundled with the release (-2.exe) is a bit newer SFCGAL 1.2.2**
-PostGIS 2.2.0 bundle includes:
+PostGIS 2.2.1 bundle includes:
- * PostGIS 2.2.0 with raster, [SFCGAL](http://sfcgal.org) support (1.2.0), address_standardizer, topology
+ * PostGIS 2.2.1 with raster, [SFCGAL](http://sfcgal.org) support (1.2.2), address_standardizer, topology
* PostGIS Tiger geocoder extension (targeting Tiger 2015)
* [pgRouting 2.1.0](http://docs.pgrouting.org/2.1/doc)
* Commandline raster loader (raster2pgsql), shapefile import/export (shp2pgsql,pgsql2shp)
* Commandline [osm2pgrouting 2.1.0 alpha](https://github.com/pgRouting/osm2pgrouting/tree/osm2pgrouting-2.1.0-alpha) for loading data from .osm files into pgRouting routable format
* GUI: shp2pgsql-gui which has both import and export support for geometry/geography
- * [ogrfdw 1.0](https://github.com/pramsey/pgsql-ogr-fdw) - spatial foreign data wrapper for
+ * [ogrfdw 1.0.1](https://github.com/pramsey/pgsql-ogr-fdw) - spatial foreign data wrapper for
reading both spatial (spatial columns become postgis geometry) and non-spatial data
- 9.5 has the master version (since the released 1.0 did not compile against 9.5)
+ [IMPORT FOREIGN SCHEMA](http://www.postgresonline.com/journal/archives/359-Import-Foreign-Schema-for-ogr_fdw-for-PostgreSQL-9.5.html) support for PostgreSQL 9.5 users
* [GDAL 2.0.1](http://gdal.org) with ODBC, Curl, SQLite, excel, libreoffice spreadsheet (used by both PostGIS raster and ogrfdw)
- * [pgpointcloud](https://github.com/pgpointcloud/pointcloud) 1.0.1 (9.5 will have master version 1.1 since 1.0.1 doesn't compile against 9.5) for querying LIDAR point cloud and in/out functions to convert to PostGIS geometry
+ * [pgpointcloud](https://github.com/pgpointcloud/pointcloud) 1.0.1 (9.5 will have master version 1.1 since 1.0.1 doesn't compile against 9.5)
+ for querying LIDAR point cloud and in/out functions to convert to PostGIS geometry
Installers are available for PostGIS 2.1.8 for PostgreSQL 9.2 (64-bit), PostgreSQL 9.4 (32/64-bit) (via Application stackbuilder) and [windows download][5].
NOTE: the PostgreSQL 9.2 PostGIS 2.1.8 installers and binaries require PostgreSQL 9.2.9 or above. If you had done a micro upgrade from a pre-PostgreSQL 9.2.9
