[postgis-tickets] [PostGIS] #3426: Patch to fix test_wkb_out_point failure on hppa & mips.
trac at osgeo.org
Wed Jan 13 09:19:48 PST 2016
Reporter: sebastic | Owner: robe
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.2.2
Component: postgis | Version: 2.2.x
Resolution: | Keywords:
Comment (by pramsey):
Actually, reading up on NaN some more, the problem is actually with the
tests. The WKB we are generating *should* in fact be portable between the
systems. The basic problem is that IEE NaN specifies the first portion of
the number (it's actually an identical pattern to Inf) and then says "for
the rest of the payload, do something non-zero" (to distinguish it from
Inf, which specifies a zeroed out payload). And look at our two NaN
patterns in the test are:
cu_wkb("POINT EMPTY");
CU_ASSERT_STRING_EQUAL(s, nan_val(
"00000000017FF80000000000007FF8000000000000",
"00000000017FF7FFFFFFFFFFFF7FF7FFFFFFFFFFFF"));
Strip out the first 10 chars (which are endian and type) and we get NaN
of:
7FF800000000000 /* intel */
7FF7FFFFFFFFFFFF /* mips */
They both have the *same* NaN pattern (7FF), and they both have a non-zero
payload. So if you ask either system isnan() on those numbers, you'll get
back true. So they are portable nan values. What they aren't is identical
at a string level. So our problem is with the tests, not with the code
underneath.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3426#comment:11>
