[postgis-tickets] [PostGIS] #3429: upgrade from 2.1.3 to 2.3.0dev enters infinite loop
trac at osgeo.org
Thu Jan 14 07:26:20 PST 2016
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.3.0
Component: build/upgrade/install | Version: 2.2.x
Keywords: |
I still have to try at reproducing this but an
{{{ ALTER EXTENSION postgis UPDATE }}}
resulted into an infinite loop for me.
Attaching the postgres process with gdb this is the stacktrace:
#0 init_rt_allocator (size=3488) at rt_api.c:880
#1 0x00007f2cf751d5aa in rt_raster_gdal_drivers
(drv_count=drv_count at entry=0x7fffbbdd273c, cancc=cancc at entry=0 '\000') at
rt_api.c:8975
#2 0x00007f2cf74f2233 in rtpg_assignHookGDALEnabledDrivers () at
rt_pg.c:172
#3 _PG_init () at rt_pg.c:291
#4 0x000000000075b8a2 in internal_load_library
(libname=libname at entry=0x25b7f68
"/home/postgresql-9.3.4/lib/rtpostgis-2.1.so") at dfmgr.c:284
#5 0x000000000075c2b3 in load_external_function
(filename=filename at entry=0x25b7f30 "$libdir/rtpostgis-2.1",
funcname=funcname at entry=0x25b7ef8 "RASTER_lib_version",
signalNotFound=signalNotFound at entry=1 '\001',
filehandle=filehandle at entry=0x7fffbbdd28d8) at dfmgr.c:113
The query I was running:
psql -XAtc "ALTER EXTENSION postgis UPDATE; SELECT
postgis_full_version();"
The database was initialized with postgis '2.1.3'.
The target library is "2.3.0dev r14582"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3429>
