[postgis-tickets] [PostGIS] #3429: upgrade from 2.1.3 to 2.3.0dev enters infinite loop
PostGIS trac at osgeo.org
Fri Jan 15 00:47:26 PST 2016
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  critical               |  Milestone:  PostGIS 2.2.2
 Component:  build/upgrade/install  |    Version:  2.2.x
Resolution:                         |   Keywords:
Comment (by strk):
 Interesting enough, of these two lines:
   lwnotice("XXXXX lwnotice 2.1");
   elog(NOTICE, "XXXX elog notice 2.1");
 I only get the "elog" one, which means "lwnotice" is failing to be
 effective.
 Maybe --exclude-libs=ALL is not being effective
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3429#comment:12>
