[postgis-tickets] [PostGIS] #3431: Problems buffering the output of ST_Segmentize
trac at osgeo.org
Fri Jan 15 17:43:31 PST 2016
Reporter: johnjcz | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.2
Component: postgis | Version: 2.1.x
Keywords: |
I am running into an issue where I cannot buffer the output of
{{{ST_Segmentize(geography)}}}. For example, this query...
SELECT ST_Buffer(ST_Segmentize('LINESTRING(-88 45,-90 43)'::geography,
1000), 1);
Results in this error:
ERROR: transform: couldn't project point (-88 45 0): latitude or
longitude exceeded limits (-14)
CONTEXT: SQL function "st_buffer" statement 1
Query failed
PostgreSQL said: transform: couldn't project point (-88 45 0): latitude or
However, if you explicitly case the output of ST_Segmentize to a geometry,
and then back to a geography, it works as expected:
SELECT ST_Buffer((ST_Segmentize('LINESTRING(-88 45,-90 43)'::geography,
1000)::geometry)::geography, 1);
Also, interestingly the first query works as expected when the first
longitude <= -115:
SELECT ST_Buffer(ST_Segmentize('LINESTRING(-120 45,-90 43)'::geography,
1000), 1);
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3431>
