[postgis-tickets] r14611 - #3433, ST_ClusterIntersecting gives incorrect result for MultiPoints
Daniel Baston dbaston at gmail.com
Wed Jan 20 03:57:21 PST 2016
Author: dbaston
Date: 2016-01-20 03:57:21 -0800 (Wed, 20 Jan 2016)
New Revision: 14611
   trunk/liblwgeom/cunit/cu_geos_cluster.c
   trunk/liblwgeom/lwgeom_geos_cluster.c
Modified: trunk/liblwgeom/cunit/cu_geos_cluster.c
--- trunk/liblwgeom/cunit/cu_geos_cluster.c	2016-01-19 17:07:49 UTC (rev 14610)
+++ trunk/liblwgeom/cunit/cu_geos_cluster.c	2016-01-20 11:57:21 UTC (rev 14611)
@@ -238,6 +238,23 @@
 	perform_cluster_within_distance_test(1, wkt_inputs, 2, expected_outputs, 2);
+static void multipoint_test(void)
+	/* See #3433 */
+	char* wkt_inputs_mp[] = { "MULTIPOINT ((0 0), (0 1))", "POINT (0 0)"};
+	char* expected_outputs_mp[] = { "GEOMETRYCOLLECTION(MULTIPOINT ((0 0), (0 1)), POINT (0 0))"};
+	char* wkt_inputs_gc[] = { "GEOMETRYCOLLECTION (POINT (0 0), POINT (0 1))", "POINT (0 0)"};
+	char* expected_outputs_gc[] = { "GEOMETRYCOLLECTION(GEOMETRYCOLLECTION (POINT (0 0), POINT (0 1)), POINT (0 0))"};
+	char* wkt_inputs_pt[] = { "POINT (3 3)", "POINT (3 3)"};
+	char* expected_outputs_pt[] = { "GEOMETRYCOLLECTION(POINT (3 3), POINT (3 3))"};
+	perform_cluster_intersecting_test(wkt_inputs_mp, 2, expected_outputs_mp, 1);
+	perform_cluster_intersecting_test(wkt_inputs_gc, 2, expected_outputs_gc, 1);
+	perform_cluster_intersecting_test(wkt_inputs_pt, 2, expected_outputs_pt, 1);
 void geos_cluster_suite_setup(void);
@@ -247,4 +264,5 @@
 	PG_ADD_TEST(suite, basic_distance_test);
 	PG_ADD_TEST(suite, single_input_test);
 	PG_ADD_TEST(suite, empty_inputs_test);
+	PG_ADD_TEST(suite, multipoint_test);
Modified: trunk/liblwgeom/lwgeom_geos_cluster.c
--- trunk/liblwgeom/lwgeom_geos_cluster.c	2016-01-19 17:07:49 UTC (rev 14610)
+++ trunk/liblwgeom/lwgeom_geos_cluster.c	2016-01-20 11:57:21 UTC (rev 14611)
@@ -136,12 +136,26 @@
 	if (p != q && UF_find(cxt->uf, p) != UF_find(cxt->uf, q))
-		/* Lazy initialize prepared geometry */
-		if (cxt->prep == NULL)
+		int geos_type = GEOSGeomTypeId(cxt->geoms[p]);
+		int geos_result;
+		/* Don't build prepared a geometry around a Point or MultiPoint -
+		 * there are some problems in the implementation, and it's not clear
+		 * there would be a performance benefit in any case.  (See #3433)
+		if (geos_type != GEOS_POINT && geos_type != GEOS_MULTIPOINT)
-			cxt->prep = GEOSPrepare(cxt->geoms[p]);
+			/* Lazy initialize prepared geometry */
+			if (cxt->prep == NULL)
+				cxt->prep = GEOSPrepare(cxt->geoms[p]);
+			geos_result = GEOSPreparedIntersects(cxt->prep, cxt->geoms[q]);
-		int geos_result = GEOSPreparedIntersects(cxt->prep, cxt->geoms[q]);
+		else
+			geos_result = GEOSIntersects(cxt->geoms[p], cxt->geoms[q]);
 		if (geos_result > 1)
 			cxt->error = geos_result;
