[postgis-tickets] r14984 - Style only change: remove trailing spaces
Sandro Santilli strk at kbt.io
Mon Jul 4 05:54:26 PDT 2016
Author: strk
Date: 2016-07-04 05:54:26 -0700 (Mon, 04 Jul 2016)
New Revision: 14984
   trunk/topology/sql/export/TopoJSON.sql.in
   trunk/topology/sql/manage/CopyTopology.sql.in
   trunk/topology/sql/manage/ManageHelper.sql.in
   trunk/topology/sql/manage/TopologySummary.sql.in
   trunk/topology/sql/polygonize.sql.in
   trunk/topology/sql/populate.sql.in
   trunk/topology/sql/predicates.sql.in
   trunk/topology/sql/query/GetRingEdges.sql.in
   trunk/topology/sql/query/getedgebypoint.sql.in
   trunk/topology/sql/query/getnodebypoint.sql.in
   trunk/topology/sql/sqlmm.sql.in
   trunk/topology/sql/topoelement/topoelement_agg.sql.in
   trunk/topology/sql/topogeometry/cleartopogeom.sql.in
   trunk/topology/sql/topogeometry/simplify.sql.in
   trunk/topology/sql/topogeometry/totopogeom.sql.in
   trunk/topology/sql/topogeometry/type.sql.in
Modified: trunk/topology/sql/export/TopoJSON.sql.in
--- trunk/topology/sql/export/TopoJSON.sql.in	2016-07-02 16:34:16 UTC (rev 14983)
+++ trunk/topology/sql/export/TopoJSON.sql.in	2016-07-04 12:54:26 UTC (rev 14984)
@@ -1,5 +1,5 @@
 -- PostGIS - Spatial Types for PostgreSQL
 -- http://postgis.net
@@ -152,7 +152,7 @@
       FOR rec in -- {
 WITH RECURSIVE
 _edges AS (
-  SELECT e.*,
+  SELECT e.*,
          e.left_face = ANY ( faces ) as lf,
          e.right_face = ANY ( faces ) as rf
   FROM edge e
@@ -298,9 +298,9 @@
     RAISE EXCEPTION 'Collection TopoGeometries are not supported by AsTopoJSON';
   END IF;
   RETURN json;
 END
 $$ LANGUAGE 'plpgsql' VOLATILE; -- writes into visited table
 -- } AsTopoJSON(TopoGeometry, visited_table)
Modified: trunk/topology/sql/manage/CopyTopology.sql.in
--- trunk/topology/sql/manage/CopyTopology.sql.in	2016-07-02 16:34:16 UTC (rev 14983)
+++ trunk/topology/sql/manage/CopyTopology.sql.in	2016-07-04 12:54:26 UTC (rev 14984)
@@ -1,5 +1,5 @@
@@ -44,7 +44,7 @@
   -- Update faces sequence
   EXECUTE 'SELECT setval(' || quote_literal(
       quote_ident(newtopo) || '.face_face_id_seq'
-    ) || ', (SELECT last_value FROM '
+    ) || ', (SELECT last_value FROM '
     || quote_ident(atopology) || '.face_face_id_seq))';
   -- Copy nodes
@@ -54,7 +54,7 @@
   -- Update node sequence
       quote_ident(newtopo) || '.node_node_id_seq'
     || quote_ident(atopology) || '.node_node_id_seq))';
   -- Copy edges
@@ -64,20 +64,20 @@
   -- Update edge sequence
       quote_ident(newtopo) || '.edge_data_edge_id_seq'
     || quote_ident(atopology) || '.edge_data_edge_id_seq))';
-  -- Copy layers and their TopoGeometry sequences
+  -- Copy layers and their TopoGeometry sequences
   FOR rec IN SELECT * FROM topology.layer WHERE topology_id = oldtopo_id
   LOOP
     INSERT INTO topology.layer (topology_id, layer_id, feature_type,
-      level, child_id, schema_name, table_name, feature_column)
+      level, child_id, schema_name, table_name, feature_column)
       VALUES (newtopo_id, rec.layer_id, rec.feature_type,
               rec.level, rec.child_id, newtopo,
               'LAYER' ||  rec.layer_id, '');
     -- Create layer's TopoGeometry sequences
-    EXECUTE 'SELECT last_value FROM '
-      || quote_ident(atopology) || '.topogeo_s_' || rec.layer_id
+    EXECUTE 'SELECT last_value FROM '
+      || quote_ident(atopology) || '.topogeo_s_' || rec.layer_id
       INTO STRICT n;
     EXECUTE 'CREATE SEQUENCE ' || quote_ident(newtopo)
       || '.topogeo_s_' || rec.layer_id;
Modified: trunk/topology/sql/manage/ManageHelper.sql.in
--- trunk/topology/sql/manage/ManageHelper.sql.in	2016-07-02 16:34:16 UTC (rev 14983)
+++ trunk/topology/sql/manage/ManageHelper.sql.in	2016-07-04 12:54:26 UTC (rev 14984)
@@ -1,5 +1,5 @@
 -- http://www.postgis.net
@@ -30,14 +30,14 @@
 		var_result := a_schema_name || ' already in database search_path';
 	ELSE
 		var_cur_search_path := var_cur_search_path || ', '
-                        || quote_ident(a_schema_name);
+                        || quote_ident(a_schema_name);
 		EXECUTE 'ALTER DATABASE ' || quote_ident(current_database())
                               || ' SET search_path = ' || var_cur_search_path;
 		var_result := a_schema_name || ' has been added to end of database search_path ';
 	END IF;
 	EXECUTE 'SET search_path = ' || var_cur_search_path;
   RETURN var_result;
 END
Modified: trunk/topology/sql/manage/TopologySummary.sql.in
--- trunk/topology/sql/manage/TopologySummary.sql.in	2016-07-02 16:34:16 UTC (rev 14983)
+++ trunk/topology/sql/manage/TopologySummary.sql.in	2016-07-04 12:54:26 UTC (rev 14984)
@@ -1,5 +1,5 @@
@@ -58,7 +58,7 @@
       THEN
         ret = ret || 'missing schema';
-        RETURN ret;
+        RETURN ret;
       ELSE
         ret = ret || 'missing nodes, ';
       END IF;
@@ -110,7 +110,7 @@
         ret = ret || 'Polygonal';
       WHEN rec.feature_type = 4 THEN
         ret = ret || 'Mixed';
-      ELSE
+      ELSE
         ret = ret || '???';
     END CASE;
@@ -131,7 +131,7 @@
     END;
       IF rec.level > 0 THEN
-        ret = ret || ' Hierarchy level ' || rec.level
+        ret = ret || ' Hierarchy level ' || rec.level
                   || ', child layer ' || rec.child_id || E'\n';
       END IF;
Modified: trunk/topology/sql/polygonize.sql.in
--- trunk/topology/sql/polygonize.sql.in	2016-07-02 16:34:16 UTC (rev 14983)
+++ trunk/topology/sql/polygonize.sql.in	2016-07-04 12:54:26 UTC (rev 14984)
@@ -1,5 +1,5 @@
Modified: trunk/topology/sql/populate.sql.in
--- trunk/topology/sql/populate.sql.in	2016-07-02 16:34:16 UTC (rev 14983)
+++ trunk/topology/sql/populate.sql.in	2016-07-04 12:54:26 UTC (rev 14984)
@@ -1,5 +1,5 @@
@@ -96,7 +96,7 @@
 BEGIN
 	-- Atopology and apoint are required
 	IF atopology IS NULL OR apoint IS NULL THEN
 		RAISE EXCEPTION 'Invalid null argument';
 	END IF;
@@ -111,7 +111,7 @@
 	-- Check if a coincident node already exists
 	-- We use index AND x/y equality
 	FOR rec IN EXECUTE 'SELECT node_id FROM '
@@ -127,7 +127,7 @@
 	-- (endpoints are fine)
 	FOR rec IN EXECUTE 'SELECT edge_id FROM '
-		|| quote_ident(atopology) || '.edge '
+		|| quote_ident(atopology) || '.edge '
 		|| 'WHERE ST_DWithin($1, geom, 0) AND '
     || 'NOT ST_Equals($1, ST_StartPoint(geom)) AND '
     || 'NOT ST_Equals($1, ST_EndPoint(geom))'
@@ -164,12 +164,12 @@
 	-- Insert the new row
 	EXECUTE 'INSERT INTO ' || quote_ident(atopology)
-		|| '.node(node_id, containing_face, geom)
+		|| '.node(node_id, containing_face, geom)
 		VALUES(' || nodeid || ',' || coalesce(containing_face::text, 'NULL')
     || ',$1)' USING apoint;
 	RETURN nodeid;
 END
@@ -209,7 +209,7 @@
 -- e dell' Ambiente [RT-SIGTA].
 -- For the project: "Sviluppo strumenti software per il trattamento di dati
 -- geografici basati su QuantumGIS e Postgis (CIG 0494241492)"
 CREATE OR REPLACE FUNCTION topology.AddEdge(atopology varchar, aline geometry)
 	RETURNS int
 AS
@@ -217,11 +217,11 @@
 DECLARE
 	edgeid int;
 	rec RECORD;
-  ix geometry;
+  ix geometry;
 BEGIN
 	IF atopology IS NULL OR aline IS NULL THEN
 	END IF;
@@ -262,7 +262,7 @@
 	-- on anything but endpoints
 	-- Following DE-9 Intersection Matrix represent
-	-- the only relation we accept.
+	-- the only relation we accept.
 	--    F F 1
 	--    F * *
@@ -357,7 +357,7 @@
     USING aline;
 	RETURN edgeid;
 END
@@ -395,7 +395,7 @@
 CREATE OR REPLACE FUNCTION topology.AddFace(atopology varchar, apoly geometry, force_new boolean DEFAULT FALSE)
 	RETURNS int
 AS
@@ -424,7 +424,7 @@
 BEGIN
   -- Atopology and apoly are required
   IF atopology IS NULL OR apoly IS NULL THEN
   END IF;
@@ -494,20 +494,20 @@
         loc = ST_LineLocatePoint(edgeseg, p3);
         -- WARNING: this is as robust as length of edgeseg allows...
         IF loc > 0.9 THEN
-          -- shift last point down
+          -- shift last point down
           p2 = ST_LineInterpolatePoint(edgeseg, loc - 0.1);
         ELSIF loc < 0.1 THEN
           -- shift first point up
-          p1 = ST_LineInterpolatePoint(edgeseg, loc + 0.1);
+          p1 = ST_LineInterpolatePoint(edgeseg, loc + 0.1);
         ELSE
           -- when ring start point is in between, we swap the points
           p3 = p1; p1 = p2; p2 = p3;
         END IF;
       END IF;
-      right_side = ST_LineLocatePoint(bounds, p1) <
+      right_side = ST_LineLocatePoint(bounds, p1) <
                    ST_LineLocatePoint(bounds, p2);
 #ifdef POSTGIS_TOPOLOGY_DEBUG
       RAISE DEBUG 'Edge % (left:%, right:%) - ring : % - right_side : %',
         rec.edge_id, rec.left_face, rec.right_face, rrec.path, right_side;
@@ -552,7 +552,7 @@
   -- If the test fail either we need to add more edges
   -- from the polygon ring or we need to split
   -- some of the existing ones.
   bounds = ST_Boundary(apoly);
   IF NOT ST_isEmpty(ST_SymDifference(bounds, all_edges)) THEN
     IF NOT ST_isEmpty(ST_Difference(bounds, all_edges)) THEN
@@ -587,7 +587,7 @@
   END LOOP;
-  -- Insert new face
+  -- Insert new face
@@ -626,7 +626,7 @@
-  -- Set left_face/right_face of any contained edge
+  -- Set left_face/right_face of any contained edge
   EXECUTE 'UPDATE '
@@ -637,9 +637,9 @@
     || ' WHERE ST_Contains($1, geom)'
     USING apoly;
-  -- Set containing_face of any contained node
+  -- Set containing_face of any contained node
   EXECUTE 'UPDATE '
     || '.node SET containing_face = '
@@ -648,22 +648,22 @@
     USING apoly;
   RETURN faceid;
 END
 --} AddFace
 -- Functions to incrementally populate a topology
 --  TopoGeo_AddPoint(toponame, pointgeom, tolerance)
---  Add a Point into a topology, with an optional tolerance
+--  Add a Point into a topology, with an optional tolerance
 CREATE OR REPLACE FUNCTION topology.TopoGeo_AddPoint(atopology varchar, apoint geometry, tolerance float8 DEFAULT 0)
 	RETURNS int AS
@@ -674,7 +674,7 @@
 --  TopoGeo_addLinestring(toponame, linegeom, tolerance)
---  Add a LineString into a topology
+--  Add a LineString into a topology
 CREATE OR REPLACE FUNCTION topology.TopoGeo_addLinestring(atopology varchar, aline geometry, tolerance float8 DEFAULT 0)
@@ -686,7 +686,7 @@
 --  TopoGeo_AddPolygon(toponame, polygeom, tolerance)
---  Add a Polygon into a topology
+--  Add a Polygon into a topology
 CREATE OR REPLACE FUNCTION topology.TopoGeo_AddPolygon(atopology varchar, apoly geometry, tolerance float8 DEFAULT 0)
@@ -698,7 +698,7 @@
 --  TopoGeo_AddGeometry(toponame, geom, tolerance)
---  Add a Geometry into a topology
+--  Add a Geometry into a topology
 CREATE OR REPLACE FUNCTION topology.TopoGeo_AddGeometry(atopology varchar, ageom geometry, tolerance float8 DEFAULT 0)
 	RETURNS void AS
Modified: trunk/topology/sql/predicates.sql.in
--- trunk/topology/sql/predicates.sql.in	2016-07-02 16:34:16 UTC (rev 14983)
+++ trunk/topology/sql/predicates.sql.in	2016-07-04 12:54:26 UTC (rev 14984)
@@ -10,7 +10,7 @@
 -- the terms of the GNU General Public Licence. See the COPYING file.
 -- Author: Sandro Santilli <strk at keybit.net>
 --  Overloaded spatial predicates for TopoGeometry inputs
@@ -79,9 +79,9 @@
     IF tg2.type = 1 THEN -- point/point
   --  Two [multi]point features intersect if they share
-  --  any Node
+  --  any Node
@@ -105,13 +105,13 @@
       RETURN FALSE; -- no elements shared
     ELSIF tg2.type = 2 THEN -- point/line
   --  A [multi]point intersects a [multi]line if they share
-  --  any Node.
+  --  any Node.
@@ -145,7 +145,7 @@
     ELSIF tg2.type = 3 THEN -- point/polygon
   --  A [multi]point intersects a [multi]polygon if any
   --  Node of the point is contained in any face of the
   --  polygon OR ( is end_node or start_node of any edge
@@ -232,9 +232,9 @@
   ELSIF tg1.type = 2 THEN -- [multi]line
     IF tg2.type = 2 THEN -- line/line
   --  A [multi]line intersects a [multi]line if they share
-  --  any Node.
+  --  any Node.
@@ -275,7 +275,7 @@
     ELSIF tg2.type = 3 THEN -- line/polygon
   -- A [multi]line intersects a [multi]polygon if they share
   -- any Node (touch-only case), or if any line edge has any
   -- polygon face on the left or right (full-containment case
@@ -311,7 +311,7 @@
         || ' AND ( '
-        -- Check if E1 have left-or-right face
+        -- Check if E1 have left-or-right face
         -- being part of R2.element_id
         || ' e1.left_face = r2.element_id '
         || ' OR '
@@ -354,7 +354,7 @@
     IF tg2.type = 3 THEN -- polygon/polygon
   -- A [multi]polygon intersects a [multi]polygon if they share
   -- any Node (touch-only case), or if any face edge has any of the
   -- other polygon face on the left or right (full-containment case
@@ -395,7 +395,7 @@
         -- Check if any edge from a polygon face
         -- has any of the other polygon face
-        -- on the left or right
+        -- on the left or right
         || ' OR '
         || ' e1.right_face = r2.element_id '
@@ -483,7 +483,7 @@
         SELECT name FROM topology.topology into toponame
                 WHERE id = tg1.topology_id;
-  -- Two geometries are equal if they are composed by
+  -- Two geometries are equal if they are composed by
   -- the same TopoElements
   FOR rec IN EXECUTE 'SELECT * FROM '
     || ' topology.GetTopoGeomElements('
Modified: trunk/topology/sql/query/GetRingEdges.sql.in
--- trunk/topology/sql/query/GetRingEdges.sql.in	2016-07-02 16:34:16 UTC (rev 14983)
+++ trunk/topology/sql/query/GetRingEdges.sql.in	2016-07-04 12:54:26 UTC (rev 14984)
@@ -1,5 +1,5 @@
@@ -24,7 +24,7 @@
 -- Return a list of edges (sequence, id) resulting by starting from the
 -- given edge and following the leftmost turn at each encountered node.
--- Edge ids are signed, they are negative if traversed backward.
+-- Edge ids are signed, they are negative if traversed backward.
 -- Sequence numbers start with 1.
 -- Use a negative starting_edge to follow its rigth face rather than
Modified: trunk/topology/sql/query/getedgebypoint.sql.in
--- trunk/topology/sql/query/getedgebypoint.sql.in	2016-07-02 16:34:16 UTC (rev 14983)
+++ trunk/topology/sql/query/getedgebypoint.sql.in	2016-07-04 12:54:26 UTC (rev 14984)
@@ -1,5 +1,5 @@
@@ -22,7 +22,7 @@
 -- Returns return the integer ID if there is an edge on the Point.
--- When the Point is even a Node it raise an exception.
+-- When the Point is even a Node it raise an exception.
 -- This case is testable with the GetNodeByPoint(atopology, apoint, tol)
 -- If there isn't any edge in the Point, GetEdgeByPoint return 0.
Modified: trunk/topology/sql/query/getnodebypoint.sql.in
--- trunk/topology/sql/query/getnodebypoint.sql.in	2016-07-02 16:34:16 UTC (rev 14983)
+++ trunk/topology/sql/query/getnodebypoint.sql.in	2016-07-04 12:54:26 UTC (rev 14984)
@@ -1,5 +1,5 @@
Modified: trunk/topology/sql/sqlmm.sql.in
--- trunk/topology/sql/sqlmm.sql.in	2016-07-02 16:34:16 UTC (rev 14983)
+++ trunk/topology/sql/sqlmm.sql.in	2016-07-04 12:54:26 UTC (rev 14984)
@@ -1,5 +1,5 @@
@@ -10,8 +10,8 @@
 /* #define POSTGIS_TOPOLOGY_DEBUG 1 */
@@ -38,7 +38,7 @@
 --  ST_GetFaceEdges(atopology, aface)
 CREATE OR REPLACE FUNCTION topology.ST_GetFaceEdges(toponame varchar, face_id integer)
   RETURNS SETOF topology.GetFaceEdges_ReturnType AS
 	'MODULE_PATHNAME', 'ST_GetFaceEdges'
@@ -52,12 +52,12 @@
 --  ST_NewEdgeHeal(atopology, anedge, anotheredge)
 -- Not in the specs:
--- * Refuses to heal two edges if any of the two is closed
+-- * Refuses to heal two edges if any of the two is closed
 -- * Raise an exception when trying to heal an edge with itself
 -- * Raise an exception if any TopoGeometry is defined by only one
 --   of the two edges
 -- * Update references in the Relation table.
 CREATE OR REPLACE FUNCTION topology.ST_NewEdgeHeal(toponame varchar, e1id integer, e2id integer)
   RETURNS int AS
   'MODULE_PATHNAME','ST_NewEdgeHeal'
@@ -72,7 +72,7 @@
 -- * Returns the id of the node being removed
 --   of the two edges
@@ -93,12 +93,12 @@
 --   of the two faces that will dissolve.
--- * Raise an exception if any TopoGeometry is defined by
+-- * Raise an exception if any TopoGeometry is defined by
 --   the edge being removed.
 -- * Properly set containg_face on nodes that remains isolated by the drop
 -- * Update containg_face for isolated nodes in the dissolved faces
 CREATE OR REPLACE FUNCTION topology.ST_RemEdgeNewFace(toponame varchar, e1id integer)
   RETURNS int AS
@@ -115,7 +115,7 @@
@@ -135,7 +135,7 @@
 -- X.3.16
 --  ST_GetFaceGeometry(atopology, aface)
 CREATE OR REPLACE FUNCTION topology.ST_GetFaceGeometry(toponame varchar, aface integer)
   RETURNS GEOMETRY AS
 	'MODULE_PATHNAME', 'ST_GetFaceGeometry'
@@ -145,7 +145,7 @@
 -- Topo-Geo and Topo-Net 3: Routine Details
--- X.3.1
+-- X.3.1
 --  ST_AddIsoNode(atopology, aface, apoint)
@@ -157,7 +157,7 @@
--- X.3.2
+-- X.3.2
 --  ST_MoveIsoNode(atopology, anode, apoint)
@@ -169,7 +169,7 @@
--- X.3.3
+-- X.3.3
 --  ST_RemoveIsoNode(atopology, anode)
@@ -192,7 +192,7 @@
--- X.3.7
+-- X.3.7
 --  ST_RemoveIsoEdge(atopology, anedge)
@@ -204,7 +204,7 @@
--- X.3.8
+-- X.3.8
 --  ST_NewEdgesSplit(atopology, anedge, apoint)
@@ -219,7 +219,7 @@
--- X.3.9
+-- X.3.9
 --  ST_ModEdgeSplit(atopology, anedge, apoint)
@@ -234,10 +234,10 @@
--- X.3.4
+-- X.3.4
 --  ST_AddIsoEdge(atopology, anode, anothernode, acurve)
 -- * Reset containing_face for starting and ending point,
 --   as they stop being isolated nodes
@@ -259,7 +259,7 @@
 -- @param anedge the directed edge to get adjacents from
 --        if positive `anode' is assumed to be its start node
 --        if negative `anode' is assumed to be its end node
 -- @todo DROP, NOT NEEDED ANYMORE (might need to go in some _drop, I guess)
 CREATE OR REPLACE FUNCTION topology._ST_AdjacentEdges(atopology varchar, anode integer, anedge integer)
@@ -507,7 +507,7 @@
   FOR rec IN SELECT geom FROM ST_Dump(points)
   LOOP
     -- Use the node to split edges
-    SELECT ST_Collect(geom)
+    SELECT ST_Collect(geom)
     FROM ST_Dump(ST_Split(nodededges, rec.geom))
     INTO STRICT nodededges;
   END LOOP;
@@ -524,7 +524,7 @@
   WITH edges AS ( SELECT geom FROM ST_Dump(nodededges) )
   SELECT ST_Union( -- TODO: ST_UnaryUnion ?
-          COALESCE(ST_UnaryUnion(ST_Collect(geom)),
+          COALESCE(ST_UnaryUnion(ST_Collect(geom)),
             ST_SetSRID('POINT EMPTY'::geometry, topoinfo.SRID)),
           COALESCE(points,
@@ -540,7 +540,7 @@
 #endif
-  -- Add all nodes as isolated so that
+  -- Add all nodes as isolated so that
   -- later calls to AddEdgeModFace will tweak their being
   -- isolated or not...
@@ -548,8 +548,8 @@
   LOOP
     PERFORM topology.ST_AddIsoNode(atopology, 0, rec.geom);
   END LOOP;
   FOR rec IN SELECT geom FROM ST_Dump(nodededges)
   LOOP
     SELECT topology.GetNodeByPoint(atopology, st_startpoint(rec.geom), 0)
Modified: trunk/topology/sql/topoelement/topoelement_agg.sql.in
--- trunk/topology/sql/topoelement/topoelement_agg.sql.in	2016-07-02 16:34:16 UTC (rev 14983)
+++ trunk/topology/sql/topoelement/topoelement_agg.sql.in	2016-07-04 12:54:26 UTC (rev 14984)
@@ -1,5 +1,5 @@
@@ -10,7 +10,7 @@
--- TopoElement management functions
+-- TopoElement management functions
Modified: trunk/topology/sql/topogeometry/cleartopogeom.sql.in
--- trunk/topology/sql/topogeometry/cleartopogeom.sql.in	2016-07-02 16:34:16 UTC (rev 14983)
+++ trunk/topology/sql/topogeometry/cleartopogeom.sql.in	2016-07-04 12:54:26 UTC (rev 14984)
@@ -1,5 +1,5 @@
@@ -11,7 +11,7 @@
---  Clear the contents of a TopoGeometry
+--  Clear the contents of a TopoGeometry
 CREATE OR REPLACE FUNCTION topology.clearTopoGeom(tg topology.TopoGeometry)
Modified: trunk/topology/sql/topogeometry/simplify.sql.in
--- trunk/topology/sql/topogeometry/simplify.sql.in	2016-07-02 16:34:16 UTC (rev 14983)
+++ trunk/topology/sql/topogeometry/simplify.sql.in	2016-07-04 12:54:26 UTC (rev 14984)
@@ -1,5 +1,5 @@
@@ -100,7 +100,7 @@
   ELSIF tg.type = 2 THEN -- [multi]line -- }{
-    sql :=
+    sql :=
       'SELECT st_multi(ST_LineMerge(ST_Node(ST_Collect(ST_Simplify(e.geom,'
       || tolerance || '))))) as g FROM '
       || quote_ident(topology_info.name) || '.edge e, '
@@ -110,10 +110,10 @@
       || ' AND r.element_type = 2 '
       || ' AND abs(r.element_id) = e.edge_id';
     EXECUTE sql INTO geom;
   ELSIF tg.type = 1 THEN -- [multi]point -- }{
-    -- Can't simplify points...
+    -- Can't simplify points...
     geom := topology.Geometry(tg);
   ELSIF tg.type = 4 THEN -- mixed collection -- }{
Modified: trunk/topology/sql/topogeometry/totopogeom.sql.in
--- trunk/topology/sql/topogeometry/totopogeom.sql.in	2016-07-02 16:34:16 UTC (rev 14983)
+++ trunk/topology/sql/topogeometry/totopogeom.sql.in	2016-07-04 12:54:26 UTC (rev 14984)
@@ -1,5 +1,5 @@
@@ -66,7 +66,7 @@
   END IF;
   -- Check type compatibility and create empty TopoGeometry
   -- 1:puntal, 2:lineal, 3:areal, 4:collection
@@ -187,7 +187,7 @@
   END IF;
   -- Check type compatibility and set TopoGeometry type
@@ -230,7 +230,7 @@
         'Unexpected feature dimension %', ST_Dimension(ageom);
   END IF;
-  -- Now that we have an empty topogeometry, we loop over distinct components
+  -- Now that we have an empty topogeometry, we loop over distinct components
   -- and add them to the definition of it. We add them as soon
   -- as possible so that each element can further edit the
   -- definition by splitting
Modified: trunk/topology/sql/topogeometry/type.sql.in
--- trunk/topology/sql/topogeometry/type.sql.in	2016-07-02 16:34:16 UTC (rev 14983)
+++ trunk/topology/sql/topogeometry/type.sql.in	2016-07-04 12:54:26 UTC (rev 14984)
@@ -1,5 +1,5 @@
