[postgis-tickets] [PostGIS] #3587: lwgeom_mindistance2d slows down topology loading
trac at osgeo.org
Mon Jul 4 14:21:16 PDT 2016
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.3
Component: topology | Version: 2.2.x
Resolution: | Keywords: performance
Comment (by strk):
I confirm the MonotoneChain / Sweepline based algorithm is used for
constructing the lines topologies (for ST_Intersects / ST_Relate).
If we take the STRTree route, GEOS-3.6.0 (unreleased) will have a
GEOSSTRtree_nearest function, so we could build a tree containing the
envelopes of each segment (or monotonechain) of the longest geometry and
then query it for closest segment (or chain) on each of the shorter
geometry segments.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3587#comment:23>
