[postgis-tickets] [PostGIS] #3587: lwgeom_mindistance2d slows down topology loading
PostGIS trac at osgeo.org
Mon Jul 4 16:39:30 PDT 2016
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 2.2.3
 Component:  topology  |    Version:  2.2.x
Resolution:            |   Keywords:  performance
Changes (by strk):
 * cc: dbaston (added)
Comment:
 Daniel, given I'm getting a segment which doesn't seem to be the closest
 one from GEOSSTRtree_nearest, maybe you want to take a look at the PR too
 ? There could be a bug in GEOS.
 What I'm doing:
  1. Creating an STRTree with node capacity 10
  2. Populating the tree with 43519 segments
  3. Finding the closest segment to each of 3152 segments of the other
 geometry
  4. Computing the closest points within the segment pair
 The problem is that the brute force approach finds a pair of segments
 which are closer than the ones found by GEOSSTRtree_nearest
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3587#comment:28>
