[postgis-tickets] r14998 - Add drone and docker config
Sandro Santilli strk at kbt.io
Tue Jul 19 14:42:14 PDT 2016
Author: strk
Date: 2016-07-19 14:42:13 -0700 (Tue, 19 Jul 2016)
New Revision: 14998
Added:
   trunk/.drone.yml
   trunk/docker/
   trunk/docker/build-test/
   trunk/docker/build-test/Dockerfile.trisquel
   trunk/docker/build-test/Makefile
Added: trunk/.drone.yml
--- trunk/.drone.yml	                        (rev 0)
+++ trunk/.drone.yml	2016-07-19 21:42:13 UTC (rev 14998)
@@ -0,0 +1,11 @@
+# See http://readme.drone.io/usage/overview
+pipeline:
+  build:
+    image: docker.kbt.io/postgis/build-test:trisquel
+    commands:
+      - service postgresql start
+      - su -l postgres -c "createuser -s `whoami`"
+      - ./autogen.sh
+      - ./configure
+      - make
+      - make check
Added: trunk/docker/build-test/Dockerfile.trisquel
--- trunk/docker/build-test/Dockerfile.trisquel	                        (rev 0)
+++ trunk/docker/build-test/Dockerfile.trisquel	2016-07-19 21:42:13 UTC (rev 14998)
@@ -0,0 +1,7 @@
+FROM kpengboy/trisquel
+RUN apt-get update -qq && apt-get install -y \
+          postgresql-9.3 postgresql-server-dev-9.3 \
+          build-essential autoconf libtool libcunit1-dev \
+          xsltproc docbook-xsl docbook-mathml dblatex \
+          libproj-dev libgdal-dev libgeos-dev libjson0-dev
Added: trunk/docker/build-test/Makefile
--- trunk/docker/build-test/Makefile	                        (rev 0)
+++ trunk/docker/build-test/Makefile	2016-07-19 21:42:13 UTC (rev 14998)
@@ -0,0 +1,13 @@
+DOCKER=docker
+REGISTRY=docker.kbt.io
+NAME=$(REGISTRY)/postgis/build-test
+all: trisquel
+push: trisquel-push
+trisquel:
+	$(DOCKER) build -t $(NAME):trisquel - < Dockerfile.trisquel
+trisquel-push:
+	$(DOCKER) push $(NAME):trisquel
