[postgis-tickets] [PostGIS] #3601: Translation Backrolled
PostGIS trac at osgeo.org
Sat Jul 23 02:25:59 PDT 2016
  Reporter:  ruvyn          |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  high           |  Milestone:  PostGIS 2.3.0
 Component:  documentation  |    Version:  trunk
Resolution:                 |   Keywords:  PostGIS 2.3.0dev Manual
Comment (by strk):
 If I "make pull-tx" right now I see many changes to the ko_KR translation,
 and not any other.
 Reviewing the changes I see that the revision date of the old one was
 2015-09-29, and author was myself. The new one has date 2016-07-20 and you
 are the author. There is no trace in the repository showing _who_ pushed
 the 2015-09-29 translations to Transifex, does Transifex known ?
 I've committed the changes with r15023. Should we try contenting a smaller
 change, for test purpose ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3601#comment:2>
