[postgis-tickets] r15025 - #3496 patch commit - Make postgis non-relocateable and schema qualify at least core functions
Regina Obe lr at pcorp.us
Wed Jul 27 14:50:30 PDT 2016
Author: robe
Date: 2016-07-27 14:50:30 -0700 (Wed, 27 Jul 2016)
New Revision: 15025
   trunk/extensions/postgis/Makefile.in
   trunk/extensions/postgis/postgis.control.in
   trunk/raster/rt_pg/Makefile.in
   trunk/raster/rt_pg/rtpostgis.sql.in
make postgis extension not schema relocateble
revise several raster functions to use schema qualified operators and function calls
revise make scripts to strip out schema qualified for non-extension installed, and keep for extension installed
Modified: trunk/extensions/postgis/Makefile.in
--- trunk/extensions/postgis/Makefile.in	2016-07-25 08:38:22 UTC (rev 15024)
+++ trunk/extensions/postgis/Makefile.in	2016-07-27 21:50:30 UTC (rev 15025)
@@ -46,7 +46,7 @@
 	mkdir -p sql
 	cp $< $@
-sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: ../../postgis/postgis.sql ../../raster/rt_pg/rtpostgis.sql ../../utils/create_unpackaged.pl
+sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: sql_bits/postgis.sql sql_bits/rtpostgis.sql ../../utils/create_unpackaged.pl
 	mkdir -p sql
 	cat ../../postgis/postgis.sql ../../raster/rt_pg/rtpostgis.sql | $(PERL) ../../utils/create_unpackaged.pl postgis > $@
@@ -78,13 +78,13 @@
 	cp $< $@
 #strip BEGIN/COMMIT since these are not allowed in extensions
-sql_bits/rtpostgis.sql: ../../raster/rt_pg/rtpostgis.sql
+sql_bits/rtpostgis.sql: ../../raster/rt_pg/rtpostgis_for_extension.sql
 	$(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' $< > $@
 sql_bits/spatial_ref_sys_config_dump.sql: ../../spatial_ref_sys.sql ../../utils/create_spatial_ref_sys_config_dump.pl
 	../../utils/create_spatial_ref_sys_config_dump.pl $< > $@
-sql_bits/rtpostgis_upgrade.sql: ../../raster/rt_pg/rtpostgis_upgrade.sql
+sql_bits/rtpostgis_upgrade.sql: ../../raster/rt_pg/rtpostgis_upgrade_for_extension.sql
 	$(PERL) -pe "s/BEGIN\;//g ; s/COMMIT\;//g; s/^(DROP .*)\;/SELECT postgis_extension_drop_if_exists('$(EXTENSION)', '\1');\n\1\;/" $< > $@
 sql_bits/postgis_upgrade.sql: ../../postgis/postgis_upgrade.sql
Modified: trunk/extensions/postgis/postgis.control.in
--- trunk/extensions/postgis/postgis.control.in	2016-07-25 08:38:22 UTC (rev 15024)
+++ trunk/extensions/postgis/postgis.control.in	2016-07-27 21:50:30 UTC (rev 15025)
@@ -2,4 +2,4 @@
 comment = 'PostGIS geometry, geography, and raster spatial types and functions'
 default_version = '@POSTGIS_LIB_VERSION@'
 module_pathname = '$libdir/postgis- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@'
-relocatable = true
+relocatable = false
Modified: trunk/raster/rt_pg/Makefile.in
--- trunk/raster/rt_pg/Makefile.in	2016-07-25 08:38:22 UTC (rev 15024)
+++ trunk/raster/rt_pg/Makefile.in	2016-07-27 21:50:30 UTC (rev 15025)
@@ -24,7 +24,7 @@
 MODULEDIR=contrib/postgis- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@
 # Files to be copied to the contrib/ directory
-DATA_built=rtpostgis.sql rtpostgis_upgrade.sql rtpostgis_proc_set_search_path.sql uninstall_rtpostgis.sql rtpostgis_legacy.sql
+DATA_built=rtpostgis.sql rtpostgis_for_extension.sql rtpostgis_upgrade_for_extension.sql rtpostgis_upgrade.sql rtpostgis_proc_set_search_path.sql uninstall_rtpostgis.sql rtpostgis_legacy.sql
 DATA=
 # SQL preprocessor
@@ -98,11 +98,15 @@
 # Borrow the $libdir substitution from PGXS but customise by running the preprocessor
 # and adding the version number
+# replace @extschema at . with nothing, this is only used as placeholder for extension install
 %.sql: %.sql.in
 	$(SQLPP) -I../../postgis/ -I../../ $< | grep -v '^#' | \
+	$(PERL) -lpe "s'MODULE_PATHNAME'\$$libdir/rtpostgis- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@'g;s'@extschema@\.''g" > $@
+rtpostgis_for_extension.sql: rtpostgis.sql.in
+	$(SQLPP) -I../../postgis/ -I../../ $< | grep -v '^#' | \
 	$(PERL) -lpe "s'MODULE_PATHNAME'\$$libdir/rtpostgis- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@'g" > $@
 ../../liblwgeom/.libs/liblwgeom.a:
 	$(MAKE) -C ../../liblwgeom
@@ -120,9 +124,13 @@
 # SQL objects deps here
 $(SQL_OBJS): ../../postgis/sqldefines.h ../../postgis_svn_revision.h
+#this is redundant but trying to fold in with the  other just hangs
 rtpostgis_upgrade.sql.in: rtpostgis.sql ../../utils/postgis_proc_upgrade.pl
 	$(PERL) ../../utils/postgis_proc_upgrade.pl $< UNUSED > $@
+rtpostgis_upgrade_for_extension.sql.in: rtpostgis_for_extension.sql ../../utils/postgis_proc_upgrade.pl
+	$(PERL) ../../utils/postgis_proc_upgrade.pl $< UNUSED > $@
 rtpostgis_proc_set_search_path.sql: rtpostgis.sql ../../utils/postgis_proc_set_search_path.pl
 	$(PERL) ../../utils/postgis_proc_set_search_path.pl $< UNUSED > $@
@@ -130,6 +138,12 @@
 	echo 'BEGIN;' > $@
 	cat $^ | sed -e 's/^BEGIN;$$//' -e 's/^COMMIT;$$//' >> $@
 	echo 'COMMIT;' >> $@
+#this keeps the @extschema at . in place since extension machinery will replace during install
+rtpostgis_upgrade_for_extension.sql: rtpostgis_upgrade_cleanup.sql rtpostgis_upgrade_for_extension.sql.in rtpostgis_drop.sql
+	echo 'BEGIN;' > $@
+	cat $^ | sed -e 's/^BEGIN;$$//' -e 's/^COMMIT;$$//' >> $@
+	echo 'COMMIT;' >> $@
 uninstall_rtpostgis.sql: rtpostgis.sql ../../utils/create_undef.pl
 	$(PERL) ../../utils/create_undef.pl $< $(POSTGIS_PGSQL_VERSION) > $@
Modified: trunk/raster/rt_pg/rtpostgis.sql.in
--- trunk/raster/rt_pg/rtpostgis.sql.in	2016-07-25 08:38:22 UTC (rev 15024)
+++ trunk/raster/rt_pg/rtpostgis.sql.in	2016-07-27 21:50:30 UTC (rev 15025)
@@ -5728,7 +5728,7 @@
 CREATE OR REPLACE FUNCTION raster_overlap(raster, raster)
     RETURNS bool
-    AS 'select $1::geometry && $2::geometry'
+    AS 'select $1::geometry OPERATOR(@extschema at .&&) $2::geometry'
     LANGUAGE 'sql' IMMUTABLE STRICT _PARALLEL;
 -- raster/geometry functions
@@ -5748,7 +5748,7 @@
 -- Availability: 2.0.0
 CREATE OR REPLACE FUNCTION raster_geometry_overlap(raster, geometry)
     RETURNS bool
-    AS 'select $1::geometry && $2'
+    AS 'select $1::geometry OPERATOR(@extschema at .&&) $2'
 -- geometry/raster functions
@@ -5768,7 +5768,7 @@
 CREATE OR REPLACE FUNCTION geometry_raster_overlap(geometry, raster)
     RETURNS bool
-    AS 'select $1 && $2::geometry'
+    AS 'select $1 OPERATOR(@extschema at .&&) $2::geometry'
@@ -6110,13 +6110,13 @@
 CREATE OR REPLACE FUNCTION st_intersects(rast1 raster, nband1 integer, rast2 raster, nband2 integer)
 	RETURNS boolean
-	AS $$ SELECT $1 && $3 AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN _st_intersects(st_convexhull($1), st_convexhull($3)) ELSE _st_intersects($1, $2, $3, $4) END $$
+	AS $$ SELECT $1 OPERATOR(@extschema at .&&) $3 AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN @extschema at ._st_intersects(@extschema at .st_convexhull($1), @extschema at .st_convexhull($3)) ELSE @extschema at ._st_intersects($1, $2, $3, $4) END $$
 	COST 1000;
 CREATE OR REPLACE FUNCTION st_intersects(rast1 raster, rast2 raster)
 	RETURNS boolean
-	AS $$ SELECT st_intersects($1, NULL::integer, $2, NULL::integer) $$
+	AS $$ SELECT @extschema at .st_intersects($1, NULL::integer, $2, NULL::integer) $$
 	COST 1000;
@@ -6137,7 +6137,7 @@
 		_geom := ST_ConvexHull(rast);
 		IF nband IS NOT NULL THEN
-			SELECT CASE WHEN bmd.nodatavalue IS NULL THEN FALSE ELSE NULL END INTO hasnodata FROM ST_BandMetaData(rast, nband) AS bmd;
+			SELECT CASE WHEN bmd.nodatavalue IS NULL THEN FALSE ELSE NULL END INTO hasnodata FROM @extschema at .ST_BandMetaData(rast, nband) AS bmd;
 		END IF;
 		IF ST_Intersects(geom, _geom) IS NOT TRUE THEN
@@ -6146,8 +6146,8 @@
 			RETURN TRUE;
 		END IF;
-		SELECT ST_Collect(t.geom) INTO _geom FROM ST_PixelAsPolygons(rast, nband) AS t;
-		RETURN ST_Intersects(geom, _geom);
+		SELECT @extschema at .ST_Collect(t.geom) INTO _geom FROM @extschema at .ST_PixelAsPolygons(rast, nband) AS t;
+		RETURN @extschema at .ST_Intersects(geom, _geom);
 	END;
 	$$ LANGUAGE 'plpgsql' IMMUTABLE
 	COST 1000;
@@ -6155,7 +6155,7 @@
 -- This function can not be STRICT
 CREATE OR REPLACE FUNCTION st_intersects(geom geometry, rast raster, nband integer DEFAULT NULL)
 	RETURNS boolean AS
-	$$ SELECT $1 && $2::geometry AND _st_intersects($1, $2, $3); $$
+	$$ SELECT $1 OPERATOR(@extschema at .&&) $2::geometry AND @extschema at ._st_intersects($1, $2, $3); $$
 	COST 1000;
@@ -6165,13 +6165,13 @@
 CREATE OR REPLACE FUNCTION st_intersects(rast raster, geom geometry, nband integer DEFAULT NULL)
 	RETURNS boolean
-	AS $$ SELECT $1::geometry && $2 AND _st_intersects($2, $1, $3) $$
+	AS $$ SELECT $1::geometry OPERATOR(@extschema at .&&) $2 AND @extschema at ._st_intersects($2, $1, $3) $$
 	COST 1000;
 CREATE OR REPLACE FUNCTION st_intersects(rast raster, nband integer, geom geometry)
 	RETURNS boolean
-	AS $$ SELECT $1::geometry && $3 AND _st_intersects($3, $1, $2) $$
+	AS $$ SELECT $1::geometry OPERATOR(@extschema at .&&) $3 AND @extschema at ._st_intersects($3, $1, $2) $$
 	COST 1000;
@@ -6187,13 +6187,13 @@
 CREATE OR REPLACE FUNCTION st_overlaps(rast1 raster, nband1 integer, rast2 raster, nband2 integer)
 	RETURNS boolean
-	AS $$ SELECT $1 && $3 AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN _st_overlaps(st_convexhull($1), st_convexhull($3)) ELSE _st_overlaps($1, $2, $3, $4) END $$
+	AS $$ SELECT $1 OPERATOR(@extschema at .&&) $3 AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN @extschema at ._st_overlaps(@extschema at .st_convexhull($1), @extschema at .st_convexhull($3)) ELSE _st_overlaps($1, $2, $3, $4) END $$
 	COST 1000;
 CREATE OR REPLACE FUNCTION st_overlaps(rast1 raster, rast2 raster)
 	RETURNS boolean
-	AS $$ SELECT st_overlaps($1, NULL::integer, $2, NULL::integer) $$
+	AS $$ SELECT @extschema at .st_overlaps($1, NULL::integer, $2, NULL::integer) $$
 	COST 1000;
@@ -6209,13 +6209,13 @@
 CREATE OR REPLACE FUNCTION st_touches(rast1 raster, nband1 integer, rast2 raster, nband2 integer)
 	RETURNS boolean
-	AS $$ SELECT $1 && $3 AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN _st_touches(st_convexhull($1), st_convexhull($3)) ELSE _st_touches($1, $2, $3, $4) END $$
+	AS $$ SELECT $1 OPERATOR(@extschema at .&&) $3 AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN @extschema at ._st_touches(@extschema at .st_convexhull($1), @extschema at .st_convexhull($3)) ELSE @extschema at ._st_touches($1, $2, $3, $4) END $$
 	COST 1000;
 CREATE OR REPLACE FUNCTION st_touches(rast1 raster, rast2 raster)
 	RETURNS boolean
-	AS $$ SELECT st_touches($1, NULL::integer, $2, NULL::integer) $$
+	AS $$ SELECT @extschema at .st_touches($1, NULL::integer, $2, NULL::integer) $$
 	COST 1000;
@@ -6231,13 +6231,13 @@
 CREATE OR REPLACE FUNCTION st_contains(rast1 raster, nband1 integer, rast2 raster, nband2 integer)
 	RETURNS boolean
-	AS $$ SELECT $1 && $3 AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN _st_contains(st_convexhull($1), st_convexhull($3)) ELSE _st_contains($1, $2, $3, $4) END $$
+	AS $$ SELECT $1 OPERATOR(@extschema at .&&) $3 AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN @extschema at ._st_contains(@extschema at .st_convexhull($1), @extschema at .st_convexhull($3)) ELSE @extschema at ._st_contains($1, $2, $3, $4) END $$
 	COST 1000;
 CREATE OR REPLACE FUNCTION st_contains(rast1 raster, rast2 raster)
 	RETURNS boolean
-	AS $$ SELECT st_contains($1, NULL::integer, $2, NULL::integer) $$
+	AS $$ SELECT @extschema at .st_contains($1, NULL::integer, $2, NULL::integer) $$
 	COST 1000;
@@ -6253,13 +6253,13 @@
 CREATE OR REPLACE FUNCTION st_containsproperly(rast1 raster, nband1 integer, rast2 raster, nband2 integer)
 	RETURNS boolean
-	AS $$ SELECT $1 && $3 AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN _st_containsproperly(st_convexhull($1), st_convexhull($3)) ELSE _st_containsproperly($1, $2, $3, $4) END $$
+	AS $$ SELECT $1 OPERATOR(@extschema at .&&) $3 AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN @extschema at ._st_containsproperly(@extschema at .st_convexhull($1), @extschema at .st_convexhull($3)) ELSE @extschema at ._st_containsproperly($1, $2, $3, $4) END $$
 	COST 1000;
 CREATE OR REPLACE FUNCTION st_containsproperly(rast1 raster, rast2 raster)
 	RETURNS boolean
-	AS $$ SELECT st_containsproperly($1, NULL::integer, $2, NULL::integer) $$
+	AS $$ SELECT @extschema at .st_containsproperly($1, NULL::integer, $2, NULL::integer) $$
 	COST 1000;
@@ -6275,13 +6275,13 @@
 CREATE OR REPLACE FUNCTION st_covers(rast1 raster, nband1 integer, rast2 raster, nband2 integer)
 	RETURNS boolean
-	AS $$ SELECT $1 && $3 AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN _st_covers(st_convexhull($1), st_convexhull($3)) ELSE _st_covers($1, $2, $3, $4) END $$
+	AS $$ SELECT $1 OPERATOR(@extschema at .&&) $3 AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN @extschema at ._st_covers(@extschema at .st_convexhull($1), @extschema at .st_convexhull($3)) ELSE @extschema at ._st_covers($1, $2, $3, $4) END $$
 	COST 1000;
 CREATE OR REPLACE FUNCTION st_covers(rast1 raster, rast2 raster)
 	RETURNS boolean
-	AS $$ SELECT st_covers($1, NULL::integer, $2, NULL::integer) $$
+	AS $$ SELECT @extschema at .st_covers($1, NULL::integer, $2, NULL::integer) $$
 	COST 1000;
@@ -6297,13 +6297,13 @@
 CREATE OR REPLACE FUNCTION st_coveredby(rast1 raster, nband1 integer, rast2 raster, nband2 integer)
 	RETURNS boolean
-	AS $$ SELECT $1 && $3 AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN _st_coveredby(st_convexhull($1), st_convexhull($3)) ELSE _st_coveredby($1, $2, $3, $4) END $$
+	AS $$ SELECT $1 OPERATOR(@extschema at .&&) $3 AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN @extschema at ._st_coveredby(@extschema at .st_convexhull($1), @extschema at .st_convexhull($3)) ELSE @extschema at ._st_coveredby($1, $2, $3, $4) END $$
 	COST 1000;
 CREATE OR REPLACE FUNCTION st_coveredby(rast1 raster, rast2 raster)
 	RETURNS boolean
-	AS $$ SELECT st_coveredby($1, NULL::integer, $2, NULL::integer) $$
+	AS $$ SELECT @extschema at .st_coveredby($1, NULL::integer, $2, NULL::integer) $$
 	COST 1000;
@@ -6313,19 +6313,19 @@
 CREATE OR REPLACE FUNCTION _st_within(rast1 raster, nband1 integer, rast2 raster, nband2 integer)
 	RETURNS boolean
-	AS $$ SELECT _st_contains($3, $4, $1, $2) $$
+	AS $$ SELECT @extschema at ._st_contains($3, $4, $1, $2) $$
 	COST 1000;
 CREATE OR REPLACE FUNCTION st_within(rast1 raster, nband1 integer, rast2 raster, nband2 integer)
 	RETURNS boolean
-	AS $$ SELECT $1 && $3 AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN _st_within(st_convexhull($1), st_convexhull($3)) ELSE _st_contains($3, $4, $1, $2) END $$
+	AS $$ SELECT $1 OPERATOR(@extschema at .&&) $3 AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN @extschema at ._st_within(@extschema at .st_convexhull($1), @extschema at .st_convexhull($3)) ELSE @extschema at ._st_contains($3, $4, $1, $2) END $$
 	COST 1000;
 CREATE OR REPLACE FUNCTION st_within(rast1 raster, rast2 raster)
 	RETURNS boolean
-	AS $$ SELECT st_within($1, NULL::integer, $2, NULL::integer) $$
+	AS $$ SELECT @extschema at .st_within($1, NULL::integer, $2, NULL::integer) $$
 	COST 1000;
@@ -6341,13 +6341,13 @@
 CREATE OR REPLACE FUNCTION st_dwithin(rast1 raster, nband1 integer, rast2 raster, nband2 integer, distance double precision)
 	RETURNS boolean
-	AS $$ SELECT $1::geometry && ST_Expand(ST_ConvexHull($3), $5) AND $3::geometry && ST_Expand(ST_ConvexHull($1), $5) AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN _st_dwithin(st_convexhull($1), st_convexhull($3), $5) ELSE _st_dwithin($1, $2, $3, $4, $5) END $$
+	AS $$ SELECT $1::geometry OPERATOR(@extschema at .&&) ST_Expand(ST_ConvexHull($3), $5) AND $3::geometry OPERATOR(@extschema at .&&) ST_Expand(ST_ConvexHull($1), $5) AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN _st_dwithin(st_convexhull($1), st_convexhull($3), $5) ELSE _st_dwithin($1, $2, $3, $4, $5) END $$
 	COST 1000;
 CREATE OR REPLACE FUNCTION st_dwithin(rast1 raster, rast2 raster, distance double precision)
 	RETURNS boolean
-	AS $$ SELECT st_dwithin($1, NULL::integer, $2, NULL::integer, $3) $$
+	AS $$ SELECT @extschema at .st_dwithin($1, NULL::integer, $2, NULL::integer, $3) $$
 	COST 1000;
@@ -6363,7 +6363,7 @@
 CREATE OR REPLACE FUNCTION st_dfullywithin(rast1 raster, nband1 integer, rast2 raster, nband2 integer, distance double precision)
 	RETURNS boolean
-	AS $$ SELECT $1::geometry && ST_Expand(ST_ConvexHull($3), $5) AND $3::geometry && ST_Expand(ST_ConvexHull($1), $5) AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN _st_dfullywithin(st_convexhull($1), st_convexhull($3), $5) ELSE _st_dfullywithin($1, $2, $3, $4, $5) END $$
+	AS $$ SELECT $1::geometry OPERATOR(@extschema at .&&) ST_Expand(ST_ConvexHull($3), $5) AND $3::geometry OPERATOR(@extschema at .&&) ST_Expand(ST_ConvexHull($1), $5) AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN _st_dfullywithin(st_convexhull($1), st_convexhull($3), $5) ELSE _st_dfullywithin($1, $2, $3, $4, $5) END $$
 	COST 1000;
