[postgis-tickets] r15027 - perl as found by configure is not used in tiger, sfcgal, or address_standardizer extensions
Regina Obe
lr at pcorp.us
Sat Jul 30 10:39:39 PDT 2016
Author: robe
Date: 2016-07-30 10:39:39 -0700 (Sat, 30 Jul 2016)
New Revision: 15027
branches/2.2/NEWS
branches/2.2/extensions/address_standardizer/Makefile.in
branches/2.2/extensions/postgis_sfcgal/Makefile.in
branches/2.2/extensions/postgis_tiger_geocoder/Makefile.in
closes #3602 for PostGIS 2.2
tiger_data not being backed up and add upgrade test
closes #3515 for PostGIS 2.2
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS 2016-07-30 16:56:43 UTC (rev 15026)
+++ branches/2.2/NEWS 2016-07-30 17:39:39 UTC (rev 15027)
@@ -11,6 +11,9 @@
for shp2pgsql-gui (Sebastiaan Couwenberg)
- #3573, Operator <<->> incorrectly calculates m distance
- #3579, Crash in LWGEOM2GEOS
+ - #3515, tiger_data not being backed up
+ - #3602, perl as found by configure is not used
+ in tiger extension, postgis_sfcgal, address_standardizer
PostGIS 2.2.2
Modified: branches/2.2/extensions/address_standardizer/Makefile.in
--- branches/2.2/extensions/address_standardizer/Makefile.in 2016-07-30 16:56:43 UTC (rev 15026)
+++ branches/2.2/extensions/address_standardizer/Makefile.in 2016-07-30 17:39:39 UTC (rev 15027)
@@ -170,4 +170,4 @@
PGXS := @PGXS@
include $(PGXS)
+PERL = @PERL@
Modified: branches/2.2/extensions/postgis_sfcgal/Makefile.in
--- branches/2.2/extensions/postgis_sfcgal/Makefile.in 2016-07-30 16:56:43 UTC (rev 15026)
+++ branches/2.2/extensions/postgis_sfcgal/Makefile.in 2016-07-30 17:39:39 UTC (rev 15027)
@@ -87,3 +87,4 @@
PGXS := $(shell $(PG_CONFIG) --pgxs)
include $(PGXS)
+PERL = @PERL@
Modified: branches/2.2/extensions/postgis_tiger_geocoder/Makefile.in
--- branches/2.2/extensions/postgis_tiger_geocoder/Makefile.in 2016-07-30 16:56:43 UTC (rev 15026)
+++ branches/2.2/extensions/postgis_tiger_geocoder/Makefile.in 2016-07-30 17:39:39 UTC (rev 15027)
@@ -4,22 +4,26 @@
EXTVERSION = @POSTGIS_LIB_VERSION@
MINORVERSION = 2011. at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@
GREP = @GREP@
+PERL = @PERL@
-MICRO_NUMBER = $(shell echo $(EXTVERSION) | sed "s/[0-9]\.[0-9]\.\([0-9]*\)[a-zA-Z]*[0-9]*/\1/")
+MICRO_NUMBER = $(shell echo $(EXTVERSION) | \
+ $(PERL) -pe 's/\d.\d.(\d+)[a-zA-Z]*\d*/$1/'
PREREL_NUMBER = $(shell echo $(EXTVERSION) | \
- sed "s/[0-9]\.[0-9]\.\(.*\)/\1/" | \
+ $(PERL) -pe 's/\d\.\d\.(.*)/\1/' | \
$(GREP) "[a-zA-Z]" | \
- sed "s/[0-9][a-zA-Z]\([0-9]*\)[a-zA-Z]*/\1/")
+ $(PERL) -pe 's/\d+[a-zA-Z]+(\d+)/\1/'
MICRO_PREV = $(shell if test "$(MICRO_NUMBER)x" != "x"; then expr $(MICRO_NUMBER) - 1; fi)
PREREL_PREV = $(shell if test "$(PREREL_NUMBER)x" != "x"; then expr $(PREREL_NUMBER) - 1; fi)
PREREL_PREFIX = $(shell echo $(EXTVERSION) | \
- sed "s/\([0-9][a-zA-Z]*\)[0-9]*/\1/")
+ $(PERL) -pe 's/(\d+[a-zA-Z]+)\d*/\1/'
DATA = $(filter-out $(wildcard sql/*--*.sql),$(wildcard sql/*.sql))
-REGRESS = test-normalize_address
+REGRESS = test-normalize_address test-upgrade
REGRESS_OPTS = --load-extension=fuzzystrmatch --load-extension=postgis --load-extension=$(EXTENSION)
PG_CONFIG = @PG_CONFIG@
@@ -35,7 +39,7 @@
endif
ifeq ($(PG91),yes)
-all: sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql sql_minor_upgrade sql/test-normalize_address.sql sql/test-pagc_normalize_address.sql expected/test-normalize_address.out expected/test-pagc_normalize_address.out sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql sql_minor_upgrade
+all: sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql sql_minor_upgrade sql/test-normalize_address.sql sql/test-pagc_normalize_address.sql expected/test-normalize_address.out expected/test-pagc_normalize_address.out sql/test-upgrade.sql expected/test-upgrade.out sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql sql_minor_upgrade
sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql
mkdir -p sql
@@ -54,6 +58,13 @@
mkdir -p sql
cat $^ > $@
+sql/test-upgrade.sql:
+ mkdir -p sql
+ echo 'ALTER EXTENSION ${EXTENSION} UPDATE TO "$(EXTVERSION)next"' > $@
+expected/test-upgrade.out: sql/test-upgrade.sql
+ cp $< $@
sql/test-pagc_normalize_address.sql: sql_bits/test_tuples_only_unaligned.sql.in ../../extras/tiger_geocoder/regress/pagc_normalize_address_regress.sql
mkdir -p sql
cat $^ > $@
@@ -63,9 +74,13 @@
cat $^ > $@
#this is a cludge to allow upgrading from same SVN to same SVN
-sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql: ../postgis_extension_helper.sql sql_bits/remove_from_extension.sql.in sql/tiger_geocoder_upgrade_minor.sql sql_bits/mark_editable_objects.sql.in sql_bits/tiger_geocoder_comments.sql ../postgis_extension_helper_uninstall.sql
+sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql: ../postgis_extension_helper.sql sql_bits/remove_from_extension.sql.in sql/tiger_geocoder_upgrade_minor.sql sql_bits/mark_editable_objects.sql.in sql_bits/tiger_geocoder_comments.sql
mkdir -p sql
cat $^ > $@
+ echo "SELECT postgis_extension_drop_if_exists('${EXTENSION}', 'DROP SCHEMA tiger_data');" >> $@
+ cat ../postgis_extension_helper_uninstall.sql >> $@
sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql: sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql
@@ -75,6 +90,7 @@
#strip BEGIN/COMMIT since these are not allowed in extensions
#strip CREATE SCHEMA since we force extension
# to create schema by setting schema to tiger_geocoder in control
+#also remove tiger_data from extension if it is part of it
sql_bits/tiger_geocoder_minor.sql.in: ../../extras/tiger_geocoder/utility/set_search_path.sql \
../../extras/tiger_geocoder/geocode_settings.sql \
../../extras/tiger_geocoder/tiger_loader_2015.sql \
@@ -107,6 +123,7 @@
../../extras/tiger_geocoder/geocode/census_tracts_functions.sql
cat $^ > $@
+#also remove tiger_data from extension if it is part of it so data gets backed up
sql_bits/tiger_geocoder.sql.in: sql_bits/norm_addy_create.sql.in \
@@ -142,12 +159,14 @@
../../extras/tiger_geocoder/geocode/census_tracts_functions.sql \
../../extras/tiger_geocoder/topology/tiger_topology_loader.sql \
../postgis_extension_helper.sql \
- sql_bits/add_search_path.sql \
- ../postgis_extension_helper_uninstall.sql
+ sql_bits/add_search_path.sql
cat $^ > $@
sql_bits/tiger_geocoder.sql: sql_bits/tiger_geocoder.sql.in
sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' -e '/^CREATE SCHEMA/d;' $< > $@
+ $(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' $< > $@
sql_bits/add_search_path.sql: sql_bits/add_search_path.sql.in
cp $< $@
@@ -193,7 +212,7 @@
-e 's/BEGIN;//g' -e 's/COMMIT;//g' \
-sql_minor_upgrade: ../postgis_extension_helper.sql sql_bits/remove_from_extension.sql.in sql/tiger_geocoder_upgrade_minor.sql sql_bits/mark_editable_objects.sql.in sql_bits/tiger_geocoder_comments.sql ../postgis_extension_helper_uninstall.sql
+sql_minor_upgrade: sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql
for OLD_VERSION in $(UPGRADEABLE_VERSIONS); do \
cat $^ > sql/$(EXTENSION)--$$OLD_VERSION--$(EXTVERSION).sql; \
done
@@ -209,3 +228,4 @@
include $(PGXS)
+PERL=@PERL@
