[postgis-tickets] r15030 - Mark PostgreSQL 9.2 as minimum supported
Regina Obe lr at pcorp.us
Sat Jul 30 22:05:50 PDT 2016
Author: robe
Date: 2016-07-30 22:05:50 -0700 (Sat, 30 Jul 2016)
New Revision: 15030
   trunk/configure.ac
   trunk/doc/installation.xml
   trunk/doc/postgis.xml
closes #3384
Modified: trunk/configure.ac
--- trunk/configure.ac	2016-07-31 04:34:16 UTC (rev 15029)
+++ trunk/configure.ac	2016-07-31 05:05:50 UTC (rev 15030)
@@ -439,9 +439,9 @@
   PGSQL_SHAREDIR=`$PG_CONFIG --sharedir`
   AC_MSG_RESULT([checking PostgreSQL version... $PGSQL_FULL_VERSION])
-  dnl Ensure that we are using PostgreSQL >= 9.1
-  if test $POSTGIS_PGSQL_VERSION -lt 91; then
-    AC_MSG_ERROR([PostGIS requires PostgreSQL >= 9.1])
+  dnl Ensure that we are using PostgreSQL >= 9.2
+  if test $POSTGIS_PGSQL_VERSION -lt 92; then
+    AC_MSG_ERROR([PostGIS requires PostgreSQL >= 9.2])
   fi
   HAVE_BRIN=no
Modified: trunk/doc/installation.xml
--- trunk/doc/installation.xml	2016-07-31 04:34:16 UTC (rev 15029)
+++ trunk/doc/installation.xml	2016-07-31 05:05:50 UTC (rev 15030)
@@ -42,10 +42,13 @@
 psql -d yourdatabase -f postgis.sql
 psql -d yourdatabase -f postgis_comments.sql
 psql -d yourdatabase -f spatial_ref_sys.sql
+psql -d yourdatabase -f topology.sql
+psql -d yourdatabase -f topology_comments.sql
+-- only if you compiled with raster (GDAL)
 psql -d yourdatabase -f rtpostgis.sql
 psql -d yourdatabase -f raster_comments.sql
-psql -d yourdatabase -f topology.sql
-psql -d yourdatabase -f topology_comments.sql
 --if you built with sfcgal support --
 psql -d yourdatabase -f sfcgal.sql
 psql -d yourdatabase -f sfcgal_comments.sql
@@ -1358,11 +1361,46 @@
 	</sect2>
   </sect1>
-  <sect1 id="create_new_db">
-	<title>Create a spatially-enabled database on PostgreSQL lower than 9.1</title>
+  <sect1 id="create_new_db_extensions">
+	<title>Creating a spatial database using EXTENSIONS</title>
 	<para>
-	  The first step in creating a PostGIS database is to create a simple
+	 If you are using PostgreSQL 9.1+ and have compiled and installed the extensions/ postgis modules, you
+	 can create a spatial database the new way.
+	</para>
+	<para>
+	  <command>createdb [yourdatabase]</command>
+	</para>
+	<para>
+	  The core postgis extension installs PostGIS geometry, geography, raster, spatial_ref_sys and all the functions and comments with a simple:
+	  <programlisting>CREATE EXTENSION postgis;</programlisting> command.
+	</para>
+	<para>
+	  <command>psql -d [yourdatabase] -c "CREATE EXTENSION postgis;"</command>
+	</para>
+	<para>
+	  Topology is packaged as a separate extension and installable with command:
+	</para>
+	<para>
+	  <command>psql -d [yourdatabase] -c "CREATE EXTENSION postgis_topology;"</command>
+	</para>
+	<para>If you plan to restore an old backup from prior versions in this new db, run:</para>
+	<para><command>psql -d [yourdatabase] -f legacy.sql</command></para>
+	<para>You can later run <filename>uninstall_legacy.sql</filename> to get rid of the deprecated functions after you are done with restoring and cleanup.</para>
+  </sect1>
+    <sect1 id="create_new_db">
+	<title>Create a spatially-enabled database without using extensions</title>
+	<note><para>This is generally only needed if you built-PostGIS without raster support. Since raster functions are part of the postgis extension, extension support is not enabled if PostGIS is built without raster.</para></note>
+	<para> The first step in creating a PostGIS database is to create a simple
 	  PostgreSQL database.
 	</para>
@@ -1455,41 +1493,6 @@
   </sect1>
-  <sect1 id="create_new_db_extensions">
-	<title>Creating a spatial database using EXTENSIONS</title>
-	<para>
-	 If you are using PostgreSQL 9.1+ and have compiled and installed the extensions/ postgis modules, you
-	 can create a spatial database the new way.
-	</para>
-	<para>
-	  <command>createdb [yourdatabase]</command>
-	</para>
-	<para>
-	  The core postgis extension installs PostGIS geometry, geography, raster, spatial_ref_sys and all the functions and comments with a simple:
-	  <programlisting>CREATE EXTENSION postgis;</programlisting> command.
-	</para>
-	<para>
-	  <command>psql -d [yourdatabase] -c "CREATE EXTENSION postgis;"</command>
-	</para>
-	<para>
-	  Topology is packaged as a separate extension and installable with command:
-	</para>
-	<para>
-	  <command>psql -d [yourdatabase] -c "CREATE EXTENSION postgis_topology;"</command>
-	</para>
-	<para>If you plan to restore an old backup from prior versions in this new db, run:</para>
-	<para><command>psql -d [yourdatabase] -f legacy.sql</command></para>
-	<para>You can later run <filename>uninstall_legacy.sql</filename> to get rid of the deprecated functions after you are done with restoring and cleanup.</para>
-  </sect1>
   <sect1 id="installing_pagc_address_standardizer"><title>Installing and Using the address standardizer</title>
 		<para>The <code>address_standardizer</code> extension used to be a separate package that required separate download. From PostGIS 2.2 on, it is now bundled in.
 		For more information about the address_standardize, what it does, and how to configure it for your needs, refer to <xref linkend="Address_Standardizer" />.</para>
Modified: trunk/doc/postgis.xml
--- trunk/doc/postgis.xml	2016-07-31 04:34:16 UTC (rev 15029)
+++ trunk/doc/postgis.xml	2016-07-31 05:05:50 UTC (rev 15030)
@@ -13,7 +13,7 @@
 <!-- Change these values to update the version numbers referenced within the documentation -->
 <!ENTITY last_proj_release_version "4.8.0">
 <!ENTITY last_geos_release_version "3.4.0">
-<!ENTITY min_postgres_version "9.1">
+<!ENTITY min_postgres_version "9.2">
 <!ENTITY introduction SYSTEM "introduction.xml">
 <!ENTITY installation SYSTEM "installation.xml">
