[postgis-tickets] [PostGIS] #3486: function st_within
PostGIS trac at osgeo.org
Wed Mar 2 03:09:43 PST 2016
 Reporter:  giau81                              |      Owner:  pramsey
     Type:  defect                              |     Status:  new
 Priority:  medium                              |  Milestone:  PostGIS
                                                |  2.2.2
Component:  postgis                             |    Version:  2.2.x
 Keywords:  st_within,st_Contains, search_path  |
 st_within(geometry, geometry)/st_Contains(geometry, geometry) call 'SELECT
 $1 && $2 AND _ST_Contains($2,$1)' without setting public schema to
 _ST_Contains function.
 Using "set search_path = schema_name", if schema_name is not "public", the
 functions st_within(geometry, geometry)/st_Contains(geometry, geometry)
 don't work, because they call schema_name._ST_Contains($2,$1) instead of
 public._ST_Contains($2,$1).
 This problem happens during db restoring processes.
 We solve this issue modifying the function like this:
 'SELECT $1 && $2 AND public._ST_Contains($2,$1)'
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3486>
