[postgis-tickets] [PostGIS] #3165: make_dist.sh should allow for custom configure
trac at osgeo.org
Wed Mar 2 05:00:54 PST 2016
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS Future
Component: build/upgrade/install | Version: trunk
Resolution: | Keywords:
Comment (by gdt):
Good point about having to run configure being an sign of trouble, and
better to fix than to work around. I was really just trying to go down a
"use standard procedure to make tarball" path, not to push which way it
should be.
I wonder if it would be reasonable to just separate the comments build and
just do that, and expect that xsltproc is in PATH, without checking for
it. And thus not run configure.n
Longer term, perhaps comments should be built at build time, not at
tarball time.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3165#comment:4>
