[postgis-tickets] [PostGIS] #3487: wrong proj4text for epsg 31467
PostGIS trac at osgeo.org
Wed Mar 2 06:59:01 PST 2016
  Reporter:  klemensp  |      Owner:  pramsey
      Type:  defect    |     Status:  closed
  Priority:  critical  |  Milestone:  PostGIS 2.2.2
 Component:  postgis   |    Version:  2.2.x
Resolution:  invalid   |   Keywords:  proj4text
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => invalid
Comment:
 In spatial_ref_sys, the definition is
 +proj=tmerc +lat_0=0 +lon_0=9 +k=1 +x_0=3500000 +y_0=0 +datum=potsdam
 +units=m +no_defs
 The "datum" parameter embeds an implicit ellipse, whereas the epsg.io
 representation uses an explicit ellipse. Here's the code from proj.4
 defining the "potsdam" datum
 src/pj_datums.c:
 "potsdam",  "towgs84=598.1,73.7,418.2,0.202,0.045,-2.455,6.7",  "bessel",
 "Potsdam Rauenberg 1950 DHDN",
 This looks the same as what epsg.io is using. Having an explicit datum
 allows proj.4 to apply datum shift grids, where they exist, so this
 representation is preferable.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3487#comment:1>
