[postgis-tickets] [PostGIS] #3488: make_dist.sh uses non-POSIX "mv -T"
trac at osgeo.org
Wed Mar 2 08:21:48 PST 2016
Reporter: gdt | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS Future
Component: build/upgrade/install | Version: trunk
Resolution: | Keywords:
Comment (by strk):
The -T was needed to avoid moving "postgis-dev" under "postgis-2.3.0dev",
when "postgis-2.3.0dev" was available (which is always the case right
after running ./make_dist.sh.
I don't see how this patch addresses that case.
Maybe to simplify things we could just create a pid-dependently-named
working dir...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3488#comment:2>
