[postgis-tickets] r14734 - Allow passing custom configure flags and make command
Sandro Santilli
strk at keybit.net
Wed Mar 2 08:27:08 PST 2016
Author: strk
Date: 2016-03-02 08:27:07 -0800 (Wed, 02 Mar 2016)
New Revision: 14734
trunk/make_dist.sh
Patch by Greg Troxel.
Closes #3165
Modified: trunk/make_dist.sh
--- trunk/make_dist.sh 2016-03-01 18:21:42 UTC (rev 14733)
+++ trunk/make_dist.sh 2016-03-02 16:27:07 UTC (rev 14734)
@@ -14,12 +14,26 @@
# NOTE: will not work prior to 1.1.0
+# ENVIRONMENT VARIABLES:
+# CONFIGURE_ARGS passed to ./configure call
+# MAKE useed for builds (defaults to "make")
tag=trunk
version=dev
git=no
+# Define in environment if necessary to get postgis to configure,
+# which is only done to build comments.
+#CONFIGURE_ARGS=
+# Define in environment if Gnu make is not make (e.g., gmake).
+if [ "$MAKE" = "" ]; then
+ MAKE=make
+fi
[ -d ".git" ] && git=yes
[ "$git" = "yes" ] && tag=svn-$tag
@@ -66,7 +80,7 @@
owd="$PWD"
cd "$outdir"
./autogen.sh
-./configure
+./configure ${CONFIGURE_ARGS}
# generating postgis_svn_revision.h for >= 2.0.0 tags
if test -f utils/svn_repo_revision.pl; then
echo "Generating postgis_svn_revision.h"
@@ -79,18 +93,18 @@
echo "Generating documentation"
owd="$PWD"
cd "$outdir"/doc
-make comments
+${MAKE} comments
if [ $? -gt 0 ]; then
exit 1
fi
-make clean # won't drop the comment files
+${MAKE} clean # won't drop the comment files
cd "$owd"
# Run make distclean
echo "Running make distclean"
owd="$PWD"
cd "$outdir"
-make distclean
+${MAKE} distclean
if [ "$git" = "yes" ]; then
echo "Removing .git dir"
rm -rf .git
