[postgis-tickets] r14745 - #3480, copy input geometries to ST_ClusterDBSCAN
Daniel Baston
dbaston at gmail.com
Fri Mar 4 06:51:36 PST 2016
Author: dbaston
Date: 2016-03-04 06:51:36 -0800 (Fri, 04 Mar 2016)
New Revision: 14745
trunk/postgis/lwgeom_window.c
Modified: trunk/postgis/lwgeom_window.c
--- trunk/postgis/lwgeom_window.c 2016-03-04 08:29:45 UTC (rev 14744)
+++ trunk/postgis/lwgeom_window.c 2016-03-04 14:51:36 UTC (rev 14745)
@@ -69,13 +69,13 @@
if (*is_null) {
/* So that the indexes in our clustering input array can match our partition positions,
- * * toss an empty point into the clustering inputs, as a pass-through.
- * * NOTE: this will cause gaps in the output cluster id sequence.
+ * toss an empty point into the clustering inputs, as a pass-through.
+ * NOTE: this will cause gaps in the output cluster id sequence.
return lwpoint_as_lwgeom(lwpoint_construct_empty(0, 0, 0));
- g = (GSERIALIZED*) PG_DETOAST_DATUM(arg);
+ g = (GSERIALIZED*) PG_DETOAST_DATUM_COPY(arg);
return lwgeom_from_gserialized(g);
