[postgis-tickets] [PostGIS] #3490: Create perl script to add in the ALTER FUNCTION set path calls
PostGIS trac at osgeo.org
Fri Mar 4 17:34:34 PST 2016
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.2.2
 Component:  postgis  |    Version:  2.2.x
Resolution:           |   Keywords:
Comment (by robe):
 This is a little annoying. I have the script all ready and put it as part
 of create extension.  It doesn't error but also doesn't set search path of
 the functions.  I checked and the script has it.  Anyway going to check in
 my 2.3 work in a bit and back port the perl script and make file changes
 to generate the script for postgis and raster.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3490#comment:2>
