[postgis-tickets] [PostGIS] #3460: Upgrade to 2.2 doesn't adjust size of pgis_abs type
PostGIS trac at osgeo.org
Sat Mar 5 11:51:13 PST 2016
  Reporter:  dbaston  |      Owner:  dbaston
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 2.3.0
 Component:  postgis  |    Version:  2.2.x
Resolution:           |   Keywords:
Comment (by robe):
 No we don't but I guess given Paul's proposal we'd just have to have a
 test taht updates the typlen =8 does the test and then updates it back to
 16.  I suspect we wouldn't need to go thru the whole process of installing
 a PostGIS 2.2.0 testing to see the ill effects.  Though someone should to
 confirm his update is the same as a true type always being that.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3460#comment:12>
