[postgis-tickets] [PostGIS] #3496: Make postgis non-relocateable and schema qualify at least core functions
PostGIS trac at osgeo.org
Tue Mar 8 11:42:50 PST 2016
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  high     |  Milestone:  PostGIS 2.3.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 I misunderstood the docs a bit.  I blame pgAdmin for my stupidity because
 it always greyed out the schema feature in extension gui if an extension
 is marked non-relocatable.
 I did some experiments, and it does seem that we can schema qualify our
 functions, without forcing users to install postgis in postgis schema.
 Though I still think that is where we want to move for the sake of other
 extensions that may rely on postgis.
 Sooo if we have our control file look like this:
 # postgis extension
 comment = 'PostGIS geometry, geography, and raster spatial types and
 functions'
 default_version = '2.3.0dev'
 module_pathname = '$libdir/postgis-2.3'
 relocatable = false
 Then we can use the variable @extschema@ in lieu of the actual schema
 name.  This will still allow users to do:
 CREATE EXTENSION postgis SCHEMA whereever_I_damn_want_you_to_be;
 And if I then have ST_Intersects rewritten as:
 CREATE OR REPLACE FUNCTION ST_Intersects(geom1 geometry, geom2 geometry)
         RETURNS boolean
         AS 'SELECT $1 && $2 AND @extschema at ._ST_Intersects($1,$2)'
         LANGUAGE 'sql' IMMUTABLE;
 Once installed, in the desired user location, it will then become:
         RETURNS boolean
 whereever_I_damn_want_you_to_be._ST_Intersects($1,$2)'
 upon installation.  The downside being, the user can't then do:
 ALTER EXTENSION postgis SET schema public;
 They'll get a
 ERROR:  extension "postgis" does not support SET SCHEMA
 Now how to make this work nicely with non-extension piece.
 I suppose when we are creating the scripts for regular old postgis
 install.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3496>
