[postgis-tickets] r14771 - Exclude all c functions from schema qual except ST_Transform we know calls spatial_ref_sys and is an issue in materialized views and spatial indexes.
Regina Obe lr at pcorp.us
Thu Mar 10 15:18:31 PST 2016
Author: robe
Date: 2016-03-10 15:18:31 -0800 (Thu, 10 Mar 2016)
New Revision: 14771
   branches/2.2/utils/postgis_proc_set_search_path.pl
References #3490 for 2.2
Modified: branches/2.2/utils/postgis_proc_set_search_path.pl
--- branches/2.2/utils/postgis_proc_set_search_path.pl	2016-03-10 07:02:39 UTC (rev 14770)
+++ branches/2.2/utils/postgis_proc_set_search_path.pl	2016-03-10 23:18:31 UTC (rev 14771)
@@ -112,6 +112,14 @@
 			$search_path_safe = 0;
+		if ( /st_transform/i){
+			# st_transform functions query spatial_ref_sys
+			# so could fail in materialized views and spatial indexes,
+			# though often all done in C
+			$search_path_safe = 1;
 		#raster folks decided to break their func head in multiple lines
 		# so we need to do this crazy thing
 		if ($endhead != 1)
@@ -146,8 +154,12 @@
 			$endfunc = 1 if /^\s*(\$\$\s*)?LANGUAGE /i;
 			if ( $endfunc == 1 && $search_path_safe == -1 ){
-				$search_path_safe = 1 if /LANGUAGE\s+[\']*(c|plpgsql)/i;
+				$search_path_safe = 1 if /LANGUAGE\s+[\']*(plpgsql)/i;
 				$search_path_safe = 1 if /STRICT/i;
+				#exclude C functions unless we've include,
+				# in most cases except ST_Transform
+				# c functions don't call dependent functions or tables
+				$search_path_safe = 0 if /LANGUAGE\s+[\']*(c)/i;
 			last if ( $endfunc && /\;/ );
@@ -155,7 +167,7 @@
 		if ($search_path_safe == 1)
-			print "EXECUTE 'ALTER FUNCTION $funchead $endfunchead SET search_path=' || quote_ident(param_postgis_schema) || ';';\n";
+			print "EXECUTE 'ALTER FUNCTION $funchead $endfunchead SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';\n";
