[postgis-tickets] [PostGIS] #3502: Debbie failing PostGIS trunk regress tickets on PostgreSQL 9.6
trac at osgeo.org
Sat Mar 12 10:02:53 PST 2016
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.2
Component: buildbots | Version: trunk
Keywords: regress |
I thought I complained about this issue already, but can't find the
ticket.
Debbie is failing (seems only on 9.6 runs)
swapordinates .. ok
summary .. ok
temporal .. ok
tickets .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/2_3_pg9.6w64/test_87_diff)
--- tickets_expected 2016-02-26 14:25:42.278086250 +0000
+++ /var/lib/jenkins/workspace/postgis/tmp/2_3_pg9.6w64/test_87_out
2016-03-11 02:26:21.953618580 +0000
@@ -280,8 +280,8 @@
#3375|GEOMETRYCOLLECTION(POINT(0 -7))
#3399|1|1
#3399|10|10
-#3399|1000|1000
#3399|100|100
+#3399|1000|1000
ERROR: invalid KML representation
#3437a|5
#3437b|5
Even thought it shows as 2.3 only issue, I think that's because I'm
testing 9.6 only on 2.3. I had the same issue with this test on one run
on my computer against 9.5/ 2.2
So I think the main issue is this test is not deterministic because it
lacks an order by so since debbie always tests against 9.6 dev change -
its possible something in 9.6 changed in planner to make this always fail.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3502>
