[postgis-tickets] [PostGIS] #3502: Debbie failing PostGIS trunk regress tickets on ST_GeneratePoints test on PostgreSQL 9.6 (was: Debbie failing PostGIS trunk regress tickets on PostgreSQL 9.6)
PostGIS trac at osgeo.org
Sat Mar 12 10:11:43 PST 2016
PostgreSQL 9.6
  Reporter:  robe       |      Owner:  pramsey
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  PostGIS 2.3.0
 Component:  buildbots  |    Version:  trunk
Resolution:             |   Keywords:  regress
Changes (by robe):
 * milestone:  PostGIS 2.2.2 => PostGIS 2.3.0
Comment:
 okay this is only 2.3 since it's ticket on ST_GeneratePoints
 WITH g as (
 select 'POLYGON((1 0, 0 1, 1 2, 2 1, 1 0))'::geometry as geom
 n as (
 select n from unnest(ARRAY[-1,0,1,10,100,1000]) n
 pts as (
   select n,(st_dump(st_generatepoints(geom, n))).geom from g,n
 select '#3399' as t, n, count(*) from
 g, pts
 where st_contains(g.geom, pts.geom)
 group by n;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3502#comment:3>
