[postgis-tickets] [PostGIS] #3503: ST_ColorMap regress failing on PostgreSQL 9.6 debbie
trac at osgeo.org
Sat Mar 12 13:41:46 PST 2016
Reporter: robe | Owner: dustymugs
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.3.0
Component: raster | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Looking at the last couple of committs from PostgreSQL folks, It might be
this commit the screwed up the order of ST_GeneratePoints and ST_ColorMap.
Commit 9118d03a8cca3d97327c56bf89a72e328e454e63 by Tom Lane
When appropriate, postpone SELECT output expressions till after ORDER
BY.
It is frequently useful for volatile, set-returning, or expensive
functions in a SELECT's targetlist to be postponed till after ORDER BY
and LIMIT are done. Otherwise, the functions might be executed for
every row of the table despite the presence of LIMIT, and/or be executed
in an unexpected order. For example, in
SELECT x, nextval('seq') FROM tab ORDER BY x LIMIT 10; it's probably
desirable that the nextval() values are ordered the same as x, and that
nextval() is not run more than 10 times.
In the past, Postgres was inconsistent in this area: you would get the
desirable behavior if the ordering were performed via an indexscan, but
not if it had to be done by an explicit sort step. Getting the desired
behavior reliably required contortions like
FROM (SELECT x FROM tab ORDER BY x) ss LIMIT 10;
This patch conditionally postpones evaluation of pure-output target
expressions (that is, those that are not used as DISTINCT, ORDER BY, or
GROUP BY columns) so that they effectively occur after sorting, even if
an explicit sort step is necessary. Volatile expressions and
set-returning expressions are always postponed, so as to provide
consistent semantics. Expensive expressions (costing more than 10 times
typical operator cost, which by default would include any user-defined
function) are postponed if there is a LIMIT or if there are expressions
that must be postponed.
We could be more aggressive and postpone any nontrivial expression, but
there are costs associated with doing so: it requires an extra Result
plan node which adds some overhead, and postponement changes the volume
of data going through the sort step, perhaps for the worse. Since we
tend not to have very good estimates of the output width of nontrivial
expressions, it's hard to have much confidence in our ability to predict
whether postponement would increase or decrease the cost of the sort;
therefore this patch doesn't attempt to make decisions conditionally on
that. Between these factors and a general desire not to change query
behavior when there's not a demonstrable benefit, it seems best to be
conservative about applying postponement. We might tweak the decision
rules in the future, though.
Konstantin Knizhnik, heavily rewritten by me
Anyrate like I said, means we need to force the output of the set
returning funcs now more than ever:
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3503#comment:1>
