[postgis-tickets] r14788 - pass POINT EMPTY tests on fun architectures, #3426
Paul Ramsey
pramsey at cleverelephant.ca
Thu Mar 17 09:36:04 PDT 2016
Author: pramsey
Date: 2016-03-17 09:36:04 -0700 (Thu, 17 Mar 2016)
New Revision: 14788
trunk/liblwgeom/cunit/cu_out_wkb.c
Modified: trunk/liblwgeom/cunit/cu_out_wkb.c
--- trunk/liblwgeom/cunit/cu_out_wkb.c 2016-03-17 16:31:26 UTC (rev 14787)
+++ trunk/liblwgeom/cunit/cu_out_wkb.c 2016-03-17 16:36:04 UTC (rev 14788)
@@ -21,6 +21,7 @@
** Global variable to hold hex WKB strings
char *s;
+size_t s_size;
** The suite initialization function.
@@ -61,18 +62,20 @@
LWGEOM *g = lwgeom_from_wkt(wkt, LW_PARSER_CHECK_NONE);
if ( s ) free(s);
- s = (char*)lwgeom_to_wkb(g, WKB_HEX | WKB_XDR | WKB_EXTENDED, NULL);
+ s = (char*)lwgeom_to_wkb(g, WKB_HEX | WKB_XDR | WKB_EXTENDED, &s_size);
lwgeom_free(g);
+static void cu_wkb_empty_point_check(char *hex)
+ LWGEOM *g;
+ g = lwgeom_from_hexwkb(hex, LW_PARSER_CHECK_NONE);
+ CU_ASSERT(g != NULL);
+ CU_ASSERT(lwgeom_is_empty(g));
+ CU_ASSERT(g->type == POINTTYPE);
+ lwgeom_free(g);
-/* parisc and mips (at least some processors) have a different nan representation from other arches. */
-#if !defined(__hppa__) && !defined(__mips__)
-# define nan_val( v1, v2) v1
-#else
-# define nan_val( v1, v2) v2
-#endif
static void test_wkb_out_point(void)
cu_wkb("POINT(0 0 0 0)");
@@ -82,24 +85,19 @@
CU_ASSERT_STRING_EQUAL(s,"0060000001000000043FF00000000000003FF00000000000003FF0000000000000");
cu_wkb("POINT EMPTY");
- CU_ASSERT_STRING_EQUAL(s, nan_val("00000000017FF80000000000007FF8000000000000",
- "00000000017FF7FFFFFFFFFFFF7FF7FFFFFFFFFFFF"));
+ cu_wkb_empty_point_check(s);
cu_wkb("SRID=4326;POINT EMPTY");
- CU_ASSERT_STRING_EQUAL(s, nan_val("0020000001000010E67FF80000000000007FF8000000000000",
- "0020000001000010E67FF7FFFFFFFFFFFF7FF7FFFFFFFFFFFF"));
cu_wkb("POINT Z EMPTY");
- CU_ASSERT_STRING_EQUAL(s, nan_val("00800000017FF80000000000007FF80000000000007FF8000000000000",
- "00800000017FF7FFFFFFFFFFFF7FF7FFFFFFFFFFFF7FF7FFFFFFFFFFFF"));
cu_wkb("POINT M EMPTY");
- CU_ASSERT_STRING_EQUAL(s, nan_val("00400000017FF80000000000007FF80000000000007FF8000000000000",
- "00400000017FF7FFFFFFFFFFFF7FF7FFFFFFFFFFFF7FF7FFFFFFFFFFFF"));
cu_wkb("POINT ZM EMPTY");
- CU_ASSERT_STRING_EQUAL(s, nan_val("00C00000017FF80000000000007FF80000000000007FF80000000000007FF8000000000000",
- "00C00000017FF7FFFFFFFFFFFF7FF7FFFFFFFFFFFF7FF7FFFFFFFFFFFF7FF7FFFFFFFFFFFF"));
static void test_wkb_out_linestring(void)
