[postgis-tickets] r14790 - Example of using ST_AsEncodedPath with google maps
Regina Obe
lr at pcorp.us
Sat Mar 19 21:54:14 PDT 2016
Author: robe
Date: 2016-03-19 21:54:14 -0700 (Sat, 19 Mar 2016)
New Revision: 14790
branches/2.2/doc/reference_output.xml
Modified: branches/2.2/doc/reference_output.xml
--- branches/2.2/doc/reference_output.xml 2016-03-19 18:17:04 UTC (rev 14789)
+++ branches/2.2/doc/reference_output.xml 2016-03-20 04:54:14 UTC (rev 14790)
@@ -1258,7 +1258,7 @@
<refsection>
<title>Description</title>
- <para>Returns the geometry as an Encoded Polyline.</para>
+ <para>Returns the geometry as an Encoded Polyline. This is a format very useful if you are using google maps</para>
<para>Availability: 2.2.0</para>
@@ -1266,16 +1266,39 @@
<refsection>
<title>Examples</title>
+<para>Basic </para>
<programlisting>
-ST_AsEncodedPolyline(GeomFromEWKT('SRID=4326;LINESTRING(-120.2 38.5,-120.95 40.7,-126.453 43.252)'));
+SELECT ST_AsEncodedPolyline(GeomFromEWKT('SRID=4326;LINESTRING(-120.2 38.5,-120.95 40.7,-126.453 43.252)'));
--result--
|_p~iF~ps|U_ulLnnqC_mqNvxq`@
</programlisting>
+<para>Use in conjunction with geography linestring and geography segmentize, and put on google maps</para>
+<programlisting>-- the SQL for Boston to San Francisco, segments every 100 KM
+ ST_Segmentize(
+ ST_GeogFromText('LINESTRING(-71.0519 42.4935,-122.4483 37.64)'),
+ 100000)::geometry) As encodedFlightPath;</programlisting>
+<para>javascript will look something like this where $ variable you replace with query result</para>
+<programlisting><![CDATA[
+<script type="text/javascript" src="http://maps.googleapis.com/maps/api/js?libraries=geometry"></script>
+<script type="text/javascript">
+ flightPath = new google.maps.Polyline({
+ path: google.maps.geometry.encoding.decodePath("$encodedFlightPath"),
+ map: map,
+ strokeColor: '#0000CC',
+ strokeOpacity: 1.0,
+ strokeWeight: 4
+</script>
+]]></programlisting>
</refsection>
<!-- Optionally add a "See Also" section -->
<refsection>
<title>See Also</title>
- <para><xref linkend="ST_LineFromEncodedPolyline" /></para>
+ <para><xref linkend="ST_LineFromEncodedPolyline" />, <xref linked="ST_Segmentize" /></para>
</refsection>
</refentry>
</sect1>
