[postgis-tickets] [PostGIS] #3510: ST_RemoveColinearPoints
trac at osgeo.org
Tue Mar 22 08:21:15 PDT 2016
Reporter: robe | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.3.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by strk):
That's because the DP algorithm never drops the start or end points.
If you scrolled that ring to start at (2 0) it would work
strk=# select ST_AsText(ST_Simplify('POLYGON((3 0,2 0,2 2,3 2,3 4,5
4,5 2,9 2,9 0,3 0))'::geometry, 0));
st_astext
POLYGON((3 0,2 0,2 2,3 2,3 4,5 4,5 2,9 2,9 0,3 0))
(1 row)
strk=# select ST_AsText(ST_Simplify('POLYGON((2 0,2 2,3 2,3 4,5 4,5
2,9 2,9 0,3 0,2 0))'::geometry, 0));
st_astext
POLYGON((2 0,2 2,3 2,3 4,5 4,5 2,9 2,9 0,2 0))
(1 row)
We're sill missing an ST_Scroll function, which could help
here (see also #2175).
This not-crossing the "ring boundary" (structural one, as
topologically speaking a ring would not have a boundary)
is probably missing from other functions too, like
ST_RemoveRepeatedPoints.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3510#comment:6>
