[postgis-tickets] r14796 - Version bumps, release notes for 2.2.2
Paul Ramsey
pramsey at cleverelephant.ca
Tue Mar 22 10:51:16 PDT 2016
Author: pramsey
Date: 2016-03-22 10:51:16 -0700 (Tue, 22 Mar 2016)
New Revision: 14796
branches/2.2/ChangeLog
branches/2.2/NEWS
branches/2.2/README.postgis
branches/2.2/Version.config
branches/2.2/doc/release_notes.xml
branches/2.2/extensions/upgradeable_versions.mk
Modified: branches/2.2/ChangeLog
--- branches/2.2/ChangeLog 2016-03-22 16:43:29 UTC (rev 14795)
+++ branches/2.2/ChangeLog 2016-03-22 17:51:16 UTC (rev 14796)
@@ -1,3 +1,325 @@
+2016-03-20 05:07 Regina Obe <lr at pcorp.us>
+ * [r14791] doc/reference_output.xml: fix typo in last commit
+2016-03-20 04:54 Regina Obe <lr at pcorp.us>
+ * [r14790] doc/reference_output.xml: Example of using
+ ST_AsEncodedPath with google maps
+2016-03-17 16:31 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r14787] NEWS, liblwgeom/cunit/cu_out_wkb.c: fix failing tests on
+ POINT EMPTY, closes #3426
+2016-03-10 23:18 Regina Obe <lr at pcorp.us>
+ * [r14771] utils/postgis_proc_set_search_path.pl: Exclude all c
+ functions from schema qual except ST_Transform we know calls
+ spatial_ref_sys and is an issue in materialized views and spatial
+ indexes.
+ References #3490 for 2.2
+2016-03-10 07:02 Regina Obe <lr at pcorp.us>
+ * [r14770] utils/postgis_proc_set_search_path.pl: avoid adding
+ search_path to functions that take internals for input
+ closes #3497 for 2.2
+ reference #3490 cleanup avoid drop* functsion as well.
+2016-03-09 13:07 Daniel Baston <dbaston at gmail.com>
+ * [r14767] NEWS, postgis/postgis_drop_after.sql: #3460,
+ ST_ClusterWithin 'tolerance not defined' error after upgrade
+2016-03-08 19:54 Regina Obe <lr at pcorp.us>
+ * [r14763] utils/postgis_proc_set_search_path.pl: exclude
+ addgeometry*, addraster*, addoverview* from seach_path function
+ setting.
+ These in calls that don't take schema use the current search_path
+ to find table.
+ Closes #3495 for 2.2
+2016-03-08 16:05 Regina Obe <lr at pcorp.us>
+ * [r14761] raster/rt_pg/Makefile.in: fix
+ rtpostgis_proc_set_search_path.sql build.
+ Closes #2485
+2016-03-08 15:54 Regina Obe <lr at pcorp.us>
+ * [r14760] raster/rt_pg/Makefile.in: Add
+ rtpostgis_proc_set_search_path.sql to target install.
+ Closes #2485
+2016-03-06 00:32 Regina Obe <lr at pcorp.us>
+ * [r14756] NEWS: References #3435 for PostGIS 2.2 add to release
+ notes
+2016-03-06 00:30 Regina Obe <lr at pcorp.us>
+ * [r14755] liblwgeom/cunit/cu_out_x3d.c, liblwgeom/lwout_x3d.c: Use
+ Tomvantilburg suggestion and just hard-code convex='false' for
+ all IndexedFaceSets.
+ Corrects the output of wrongly rendered without affecting true
+ convex
+ References #3435 for PostGIS 2.2 (fix).
+2016-03-05 20:53 Regina Obe <lr at pcorp.us>
+ * [r14754] doc/faq.xml: fix invalid markup in last committ
+ references #3490
+2016-03-05 20:36 Regina Obe <lr at pcorp.us>
+ * [r14753] doc/faq.xml: FAQ about materialized views sometimes not
+ restoring in backup.
+ References #3490
+2016-03-05 06:57 Regina Obe <lr at pcorp.us>
+ * [r14752] NEWS, doc/faq_raster.xml, postgis/Makefile.in,
+ raster/rt_pg/Makefile.in, utils/postgis_proc_set_search_path.pl:
+ Script to set search path for raster and postgis functions
+ To fix database restore issues and materialized views
+ Closes #3490
+ Closes #3485
+ Closes #3277
+ Closes #3012
+2016-03-03 11:34 Sandro Santilli <strk at keybit.net>
+ * [r14741] liblwgeom/lwgeom_topo.c: Give more decimal digits in
+ edge-motion collision detection point
+2016-03-03 10:38 Sandro Santilli <strk at keybit.net>
+ * [r14739] make_dist.sh: Update make_dist.sh from trunk
+ Closes #3165 and #3482
+2016-02-27 08:10 Regina Obe <lr at pcorp.us>
+ * [r14712] doc/reference_measure.xml, doc/reference_processing.xml:
+ Mark ST_ClusterWithin and ST_ClusterIntersecting as taking
+ geometry sets
+ (so they are flagged as aggregates)
+ Move them to measurement and relationships section so matches 2.3
+ docs
+2016-02-26 14:35 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r14707] NEWS: #3429, news entry
+2016-02-26 11:17 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r14703] raster/loader/raster2pgsql.c,
+ raster/rt_core/librtcore.h, raster/rt_core/rt_context.c,
+ raster/rt_pg/rtpostgis.c, raster/test/cunit/cu_tester.c: Expunge
+ all trace of rt_init_allocators
+2016-02-26 10:02 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r14702] raster/rt_core/rt_context.c, raster/rt_pg/rtpostgis.c:
+ Change allocators to init with direct call instead of lazy load
+ (#3429)
+2016-02-24 16:46 Daniel Baston <dbaston at gmail.com>
+ * [r14687] NEWS, postgis/lwgeom_geos_prepared.c,
+ regress/tickets.sql, regress/tickets_expected: #3437,
+ ST_Intersects incorrect for MultiPoints
+2016-02-23 16:57 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r14668] NEWS, postgis/lwgeom_in_kml.c: #3461 ST_GeomFromKML
+ crashes Postgres when there are innerBoundaryIs and no
+ outerBoundaryIs
+2016-02-23 16:38 Sandro Santilli <strk at keybit.net>
+ * [r14667] NEWS, liblwgeom/lwgeom_topo.c: Fix crash on
+ face-collapsing edge change
+ See #3463
+2016-02-09 22:05 Sandro Santilli <strk at keybit.net>
+ * [r14658] regress/run_test.pl: Ensure restored database is created
+ the same as the initial one
+ Fixes ORDER BY consistency, probably also with the loader tests
+ already tweaked to workaround this
+ See #3444
+2016-02-09 18:20 Sandro Santilli <strk at keybit.net>
+ * [r14656] regress/run_test.pl: Re-append "topology" schema on
+ restore, with --dumprestore
+ See #3454
+2016-02-09 16:40 Sandro Santilli <strk at keybit.net>
+ * [r14653] regress/loader/Arc.select.sql,
+ regress/loader/ArcM.select.sql, regress/loader/ArcZ.select.sql,
+ regress/loader/MultiPoint.select.sql,
+ regress/loader/MultiPointM.select.sql,
+ regress/loader/MultiPointZ.select.sql,
+ regress/loader/PointZ.select.sql,
+ regress/loader/Polygon.select.sql,
+ regress/loader/PolygonM.select.sql,
+ regress/loader/PolygonZ.select.sql,
+ regress/loader/TSIPolygon.select.sql,
+ regress/loader/TSTIPolygon.select.sql,
+ regress/loader/TSTPolygon.select.sql: Do not rely on storage
+ order on querying loaded shapefiles
+ Fixes runs with RUNTESTFLAGS=--dumprestore
+ See #3444
+2016-02-09 16:18 Sandro Santilli <strk at keybit.net>
+ * [r14652] regress/run_test.pl: Add --dumprestore switch to
+ ./run_test.pl
+ See #3444
+2016-02-09 14:22 Sandro Santilli <strk at keybit.net>
+ * [r14650] extensions/postgis/Makefile.in: Really generate
+ system_ref_sys config dump for extension
+ Closes #3443
+2016-02-09 10:55 Sandro Santilli <strk at keybit.net>
+ * [r14647] postgis/postgis_drop_after.sql: Drop temporarely added
+ geometry_distance_box_nd(geometry,geometry)
+ Closes #3450
+2016-02-09 10:43 Sandro Santilli <strk at keybit.net>
+ * [r14645] postgis/postgis_drop_after.sql: Drop temporarely
+ existing deprecated st_effectivearea signature
+ See #3450
+2016-02-09 10:14 Sandro Santilli <strk at keybit.net>
+ * [r14643] postgis/postgis_drop_after.sql: Drop temporarely added
+ tkwb aggregate and functions
+ These were added during 2.2.0 development
+ but removed before going final.
+ See #3450
+2016-02-09 10:12 Sandro Santilli <strk at keybit.net>
+ * [r14642] extensions/postgis/Makefile.in: Wrap every DROP to first
+ unregister object from postgis extension
+ Also drop temporarely introduced ST_AsTWKB signature.
+ See #3450
+2016-02-07 05:50 Regina Obe <lr at pcorp.us>
+ * [r14628] doc/xsl/postgis_aggs_mm.xml.xsl,
+ extras/WFS_locks/WFS_locks.c, postgis/long_xact.c,
+ postgis/lwgeom_transform.c: Spelling error fixes from Sebastiaan
+ Couwenberg for 2.2
+ closes #3449
+2016-01-28 10:25 Sandro Santilli <strk at keybit.net>
+ * [r14619] extensions/compute_srid_contiguous_ranges.sql,
+ extensions/postgis/Makefile.in,
+ extensions/postgis/sql_bits/mark_editable_objects.sql.in,
+ utils/create_spatial_ref_sys_config_dump.pl: Automatically
+ generate system_ref_sys config dump for extension
+ See #3443
+2016-01-20 12:18 Daniel Baston <dbaston at gmail.com>
+ * [r14612] NEWS, liblwgeom/cunit/cu_geos_cluster.c,
+ liblwgeom/lwgeom_geos_cluster.c: #3433, ST_ClusterIntersecting
+ gives incorrect result for MultiPoints
+2016-01-19 17:07 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r14609] NEWS, liblwgeom/ptarray.c: #3436, memory handling
+ mistake in ptarray_clone_deep
+2016-01-19 09:18 Sandro Santilli <strk at keybit.net>
+ * [r14606] topology/postgis_topology.c: Fix bogus call to lwnotice
+ (missing param)
+2016-01-15 17:25 Sandro Santilli <strk at keybit.net>
+ * [r14602] doc/extras_tigergeocoder.xml: Typo
+2016-01-14 14:00 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r14600] spatial_ref_sys.sql: Remove VACUUM statement from
+ spatial_ref_sys
+2016-01-13 18:46 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r14598] NEWS, spatial_ref_sys.sql: #3427, update spatial_ref_sys
+ to EPSG 8.8
+2016-01-13 11:35 Sandro Santilli <strk at keybit.net>
+ * [r14595] NEWS, liblwgeom/cunit/cu_tester.h,
+ liblwgeom/lwgeom_geos_split.c: Avoid any drift of cutter point on
+ lines split
+ Should fix splitting operations on at least arm64, ppc64el and
+ s390x.
+ See #3422 and #3401 (for 2.2 branch)
+ Also turn ASSERT_DOUBLE_EQUAL back to a tolerance-free check
+ (better use a different name for tolerance-aware check,
+ so caller can decide)
+2016-01-13 00:36 Regina Obe <lr at pcorp.us>
+ * [r14592] liblwgeom/cunit/cu_out_wkb.c: Patch from Sebastiaan
+ Couwenberg to fix test_wkb_out_point failure on hppa & mips.
+ references #3426
+2016-01-11 14:29 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r14589] liblwgeom/cunit/cu_tester.h: #3422, double tests not
+ passing on all architectures
+2016-01-07 06:36 Sandro Santilli <strk at keybit.net>
+ * [r14583] liblwgeom/lwgeom_topo.c: ST_AddEdge*: avoid db access
+ for edges known to be dangling
+2016-01-06 17:30 Sandro Santilli <strk at keybit.net>
+ * [r14579] NEWS: Fix typos
+2016-01-06 15:14 Sandro Santilli <strk at keybit.net>
+ * [r14576] HOWTO_RELEASE: Reword the upgradeable_extensions.mk step
+ I really hope this will become automated in the future
+2016-01-06 11:55 Regina Obe <lr at pcorp.us>
+ * [r14571] ChangeLog: regenerated using make ChangeLog instead of
+ manually running svn2cl
2016-01-06 11:39 Regina Obe <lr at pcorp.us>
* [r14569] authors.git: less scammy
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS 2016-03-22 16:43:29 UTC (rev 14795)
+++ branches/2.2/NEWS 2016-03-22 17:51:16 UTC (rev 14796)
@@ -1,5 +1,5 @@
-PostGIS 2.2.2dev
-2016/MM/DD
+PostGIS 2.2.2
+2016/03/22
* Bug Fixes *
@@ -10,7 +10,7 @@
- #3433, ST_ClusterIntersecting incorrect for MultiPoints
- #3435, ST_AsX3D fix rendering of concave geometries
- #3436, memory handling mistake in ptarray_clone_deep
- - #3437, ST_Intersects incorrect for MultiPoints
+ - #3437, ST_ClusterIntersecting incorrect for MultiPoints
- #3461, ST_GeomFromKML crashes Postgres when there are
innerBoundaryIs and no outerBoundaryIs
- #3429, upgrading to 2.3 or from 2.1 can cause loop/hang on some
Modified: branches/2.2/README.postgis
--- branches/2.2/README.postgis 2016-03-22 16:43:29 UTC (rev 14795)
+++ branches/2.2/README.postgis 2016-03-22 17:51:16 UTC (rev 14796)
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 2.2.1
-:Date: 2015-10-XX
+:Version: 2.2.2
+:Date: 2016-03-22
:Website: http://postgis.net
This distribution contains a module which implements GIS simple features, ties
Modified: branches/2.2/Version.config
--- branches/2.2/Version.config 2016-03-22 16:43:29 UTC (rev 14795)
+++ branches/2.2/Version.config 2016-03-22 17:51:16 UTC (rev 14796)
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=2
POSTGIS_MINOR_VERSION=2
-POSTGIS_MICRO_VERSION=2dev
+POSTGIS_MICRO_VERSION=2
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
Modified: branches/2.2/doc/release_notes.xml
--- branches/2.2/doc/release_notes.xml 2016-03-22 16:43:29 UTC (rev 14795)
+++ branches/2.2/doc/release_notes.xml 2016-03-22 17:51:16 UTC (rev 14796)
@@ -4,6 +4,27 @@
<subtitle>Release Notes</subtitle>
<sect1>
+ <title>Release 2.2.2</title>
+ <para>Release date: 2016/03/22</para>
+ <para>This is a bug fix and performance improvement release.</para>
+ <simplesect>
+ <title>New Features</title>
+ <para>#3463, Fix crash on face-collapsing edge change</para>
+ <para>#3422, Improve ST_Split robustness on standard precision double systems (arm64, ppc64el, s390c, powerpc, ...)</para>
+ <para>#3427, Update spatial_ref_sys to EPSG version 8.8</para>
+ <para>#3433, ST_ClusterIntersecting incorrect for MultiPoints</para>
+ <para>#3435, ST_AsX3D fix rendering of concave geometries</para>
+ <para>#3436, memory handling mistake in ptarray_clone_deep</para>
+ <para>#3437, ST_ClusterIntersecting incorrect for MultiPoints</para>
+ <para>#3461, ST_GeomFromKML crashes Postgres when there are innerBoundaryIs and no outerBoundaryIs</para>
+ <para>#3429, upgrading to 2.3 or from 2.1 can cause loop/hang on some platforms</para>
+ <para>#3460, ST_ClusterWithin 'Tolerance not defined' error after upgrade</para>
+ <para>#3490, Raster data restore issues, materialized views. Scripts postgis_proc_set_search_path.sql, rtpostgis_proc_set_search_path.sql refer to http://postgis.net/docs/manual-2.2/RT_FAQ.html#faq_raster_data_not_restore</para>
+ <para>#3426, failing POINT EMPTY tests on fun architectures</para>
+ </simplesect>
+ </sect1>
+ <sect1>
<title>Release 2.2.1</title>
<para>Release date: 2016/01/06</para>
Modified: branches/2.2/extensions/upgradeable_versions.mk
--- branches/2.2/extensions/upgradeable_versions.mk 2016-03-22 16:43:29 UTC (rev 14795)
+++ branches/2.2/extensions/upgradeable_versions.mk 2016-03-22 17:51:16 UTC (rev 14796)
@@ -18,4 +18,5 @@
2.1.8 \
2.1.9 \
2.2.0 \
- 2.2.1
+ 2.2.1 \
+ 2.2.2
