[postgis-tickets] r14799 - Add 2.2.2 release page
Paul Ramsey
pramsey at cleverelephant.ca
Tue Mar 22 11:53:09 PDT 2016
Author: pramsey
Date: 2016-03-22 11:53:09 -0700 (Tue, 22 Mar 2016)
New Revision: 14799
Added:
web/_content/posts/2016/03-22_postgis-2.2.2.html
Added: web/_content/posts/2016/03-22_postgis-2.2.2.html
--- web/_content/posts/2016/03-22_postgis-2.2.2.html (rev 0)
+++ web/_content/posts/2016/03-22_postgis-2.2.2.html 2016-03-22 18:53:09 UTC (rev 14799)
@@ -0,0 +1,35 @@
+title: PostGIS 2.2.2 Released
+layout: post
+category: news
+tags: [release, 2.2, 2.2.2]
+author: Paul Ramsey
+thumbnail: postgis.png
+The PostGIS development team is happy to release patch for PostGIS 2.2, the 2.2.2 release. As befits a patch release, the focus is on bugs and breakages.
+**Bug Fixes and Improvements**
+ * #3463, Fix crash on face-collapsing edge change
+ * #3422, Improve `ST_Split` robustness on standard precision double systems (arm64, ppc64el, s390c, powerpc, ...)
+ * #3427, Update `spatial_ref_sys` to EPSG version 8.8
+ * #3433, `ST_ClusterIntersecting` incorrect for MultiPoints
+ * #3435, `ST_AsX3D` fix rendering of concave geometries
+ * #3436, memory handling mistake in ptarray_clone_deep
+ * #3437, `ST_ClusterIntersecting` incorrect for MultiPoints
+ * #3461, `ST_GeomFromKML` crashes Postgres when there are innerBoundaryIs and no outerBoundaryIs
+ * #3429, upgrading to 2.3 or from 2.1 can cause loop/hang on some platforms
+ * #3460, `ST_ClusterWithin` "Tolerance not defined" error after upgrade
+ * #3490, Raster [data restore](http://postgis.net/docs/manual-2.2/RT_FAQ.html#faq_raster_data_not_restore) issues, materialized views. Added scripts `postgis_proc_set_search_path.sql`, `rtpostgis_proc_set_search_path.sql`
+ * #3426, failing `POINT EMPTY` tests on fun architectures
+See the full list of changes in the [news file](http://svn.osgeo.org/postgis/tags/2.2.2/NEWS) and please [report bugs](https://trac.osgeo.org/postgis) that you find in the release.
+* [postgis-2.2.2.tar.gz]({{postgis.release_source}}/postgis-2.2.2.tar.gz)
+* [ChangeLog](https://svn.osgeo.org/postgis/tags/2.2.2/ChangeLog)
+Binary packages will appear in [repositories](http://postgis.net/install) over the coming weeks as packagers roll out builds.
+View all [closed tickets for 2.2.2][1].
+ [1]:http://trac.osgeo.org/postgis/query?status=closed&groupdesc=1&group=priority&milestone=PostGIS+2.2.2&order=priority
