[postgis-tickets] r14805 - Add 2.2.2 section
Sandro Santilli
strk at keybit.net
Wed Mar 23 04:46:25 PDT 2016
Author: strk
Date: 2016-03-23 04:46:25 -0700 (Wed, 23 Mar 2016)
New Revision: 14805
trunk/NEWS
Add 2.2.2 section
Modified: trunk/NEWS
--- trunk/NEWS 2016-03-23 11:46:17 UTC (rev 14804)
+++ trunk/NEWS 2016-03-23 11:46:25 UTC (rev 14805)
@@ -20,6 +20,29 @@
- #3465 ST_ClusterKMeans (Paul Ramsey)
- #3469 ST_MakeLine with MULTIPOINTs (Paul Norman)
+PostGIS 2.2.2
+2016/03/22
+ * Bug Fixes *
+ - #3463, Fix crash on face-collapsing edge change
+ - #3422, Improve ST_Split robustness on standard precision double
+ systems (arm64, ppc64el, s390c, powerpc, ...)
+ - #3427, Update spatial_ref_sys to EPSG version 8.8
+ - #3433, ST_ClusterIntersecting incorrect for MultiPoints
+ - #3435, ST_AsX3D fix rendering of concave geometries
+ - #3436, memory handling mistake in ptarray_clone_deep
+ - #3437, ST_Intersects incorrect for MultiPoints
+ - #3461, ST_GeomFromKML crashes Postgres when there are
+ innerBoundaryIs and no outerBoundaryIs
+ - #3429, upgrading to 2.3 or from 2.1 can cause loop/hang on some platforms
+ - #3460, ST_ClusterWithin 'Tolerance not defined' error after upgrade
+ - #3490, Raster data restore issues, materialized views
+ Scripts postgis_proc_set_search_path.sql,
+ rtpostgis_proc_set_search_path.sql refer to
+ http://postgis.net/docs/manual-2.2/RT_FAQ.html#faq_raster_data_not_restore
+ - #3426, failing POINT EMPTY tests on fun architectures
PostGIS 2.2.1
2016/01/06
