[postgis-tickets] [PostGIS] #3513: topology tests failing for PostgreSQL 9.6
trac at osgeo.org
Fri Mar 25 12:12:12 PDT 2016
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.3.0
Component: topology | Version: trunk
Keywords: |
regress/gml .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_3_pg9.6w64/test_43_diff)
--- regress/gml_expected 2015-11-27 18:02:58.521510476 +0000
/var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_3_pg9.6w64/test_43_out
2016-03-25 18:14:11.397435892 +0000
@@ -55,8 +55,8 @@
S3-visited|<TopoPoint><directedNode xlink:href="#N6" /></TopoPoint>
R1-visited|<TopoCurve><directedEdge><Edge id="E9"><directedNode
orientation="-"><Node id="N15"/></directedNode><directedNode
xlink:href="#N14" /><curveProperty><Curve
srsName="EPSG:4326"><segments><LineStringSegment><posList>9 14 21
14</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge
orientation="-"><Edge id="E10"><directedNode orientation="-"><Node
id="N13"/></directedNode><directedNode xlink:href="#N14"
srsName="EPSG:4326"><segments><LineStringSegment><posList>35 14 21
14</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge></TopoCurve>
N1N6N14-visited|<TopoPoint><directedNode><Node
id="N1"><pointProperty><Point srsName="EPSG:4326"><pos>8
30</pos></Point></pointProperty></Node></directedNode><directedNode
xlink:href="#N6" /><directedNode xlink:href="#N14" /></TopoPoint>
-P2-visited|<TopoSurface><directedFace><Face id="F4"><directedEdge
orientation="-"><Edge id="E7"><directedNode orientation="-"
xlink:href="#N17" /><directedNode><Node
id="N18"/></directedNode><curveProperty><Curve
srsName="EPSG:4326"><segments><LineStringSegment><posList>21 22 35
22</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge><Edge
id="E17"><directedNode orientation="-" xlink:href="#N13" /><directedNode
xlink:href="#N18" /><curveProperty><Curve
srsName="EPSG:4326"><segments><LineStringSegment><posList>35 14 35
orientation="-" xlink:href="#E10" /><directedEdge orientation="-"
xlink:href="#E19" /></Face></directedFace><directedFace><Face
id="F7"><directedEdge xlink:href="#E10" /><directedEdge><Edge
id="E18"><directedNode orientation="-"><Node
id="N10"/></directedNode><directedNode xlink:href="#N13"
srsName="EPSG:4326"><segments><LineStringSegment><posList>35 6 35
14</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge><Edge
id="E13"><directedNode orientation="-" xlink:href="#N9" /><directedNode
xlink:href="#N10" /><curveProperty><Curve
srsName="EPSG:4326"><segments><LineStringSegment><posList>21 6 35
6</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge><directedEdge
orientation="-" xlink:href="#E20" /></Face></directedFace></TopoSurface>
-P1-visited|<TopoSurface><directedFace><Face id="F3"><directedEdge
orientation="-"><Edge id="E6"><directedNode orientation="-"><Node
id="N16"/></directedNode><directedNode><Node
id="N17"/></directedNode><curveProperty><Curve
srsName="EPSG:4326"><segments><LineStringSegment><posList>9 22 21
id="E19"><directedNode orientation="-" xlink:href="#N14" /><directedNode
xlink:href="#N17" /><curveProperty><Curve
srsName="EPSG:4326"><segments><LineStringSegment><posList>21 14 21
xlink:href="#E9" /><directedEdge orientation="-"><Edge
id="E21"><directedNode orientation="-" xlink:href="#N15" /><directedNode
xlink:href="#N16" /><curveProperty><Curve
srsName="EPSG:4326"><segments><LineStringSegment><posList>9 14 9
22</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge></Face></directedFace><directedFace><Face
id="F6"><directedEdge orientation="-" xlink:href="#E9"
/><directedEdge><Edge id="E20"><directedNode orientation="-"><Node
id="N9"/></directedNode><directedNode xlink:href="#N14"
srsName="EPSG:4326"><segments><LineStringSegment><posList>21 6 21
id="E12"><directedNode orientation="-"><Node
id="N8"/></directedNode><directedNode xlink:href="#N9"
srsName="EPSG:4326"><segments><LineStringSegment><posList>9 6 21
orientation="-"><Edge id="E22"><directedNode orientation="-"
xlink:href="#N8" /><directedNode xlink:href="#N15" /><curveProperty><Curve
srsName="EPSG:4326"><segments><LineStringSegment><posList>9 6 9
14</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge></Face></directedFace></TopoSurface>
+P2-visited|<TopoSurface><directedFace><Face id="F4"><directedEdge
orientation="-"><Edge id="E7"><directedNode orientation="-"><Node
id="N17"/></directedNode><directedNode><Node
orientation="-" xlink:href="#E10" /><directedEdge orientation="-"><Edge
id="E13"><directedNode orientation="-"><Node
id="N9"/></directedNode><directedNode xlink:href="#N10"
orientation="-"><Edge id="E20"><directedNode orientation="-"
xlink:href="#N9" /><directedNode xlink:href="#N14" /><curveProperty><Curve
+P1-visited|<TopoSurface><directedFace><Face id="F3"><directedEdge
id="N16"/></directedNode><directedNode xlink:href="#N17"
xlink:href="#E19" /><directedEdge xlink:href="#E9" /><directedEdge
orientation="-"><Edge id="E21"><directedNode orientation="-"
xlink:href="#N15" /><directedNode xlink:href="#N16"
id="F6"><directedEdge orientation="-" xlink:href="#E9" /><directedEdge
xlink:href="#E20" /><directedEdge><Edge id="E12"><directedNode
orientation="-"><Node id="N8"/></directedNode><directedNode
xlink:href="#N9" /><curveProperty><Curve
F3F4-visited|<TopoSurface><directedFace xlink:href="#F3" /><directedFace
xlink:href="#F4" /></TopoSurface>
E7E8-visited|<TopoCurve><directedEdge xlink:href="#E7"
/><directedEdge><Edge id="E8"><directedNode orientation="-"
xlink:href="#N18" /><directedNode><Node
id="N19"/></directedNode><curveProperty><Curve
srsName="EPSG:4326"><segments><LineStringSegment><posList>35 22 47
22</posList></LineStringSegment></segments></Curve></curveProperty></Edge></directedEdge></TopoCurve>
P3-visited-idprefix|<TopoSurface><directedFace><Face
id="cd-F5"><directedEdge orientation="-" xlink:href="#cd-E8"
/><directedEdge><Edge id="cd-E15"><directedNode orientation="-"><Node
id="cd-N12"/></directedNode><directedNode xlink:href="#cd-N19"
srsName="EPSG:4326"><segments><LineStringSegment><posList>47 14 47
id="cd-E11"><directedNode orientation="-" xlink:href="#cd-N13"
/><directedNode xlink:href="#cd-N12" /><curveProperty><Curve
srsName="EPSG:4326"><segments><LineStringSegment><posList>35 14 47
orientation="-" xlink:href="#cd-E17"
/></Face></directedFace><directedFace><Face id="cd-F8"><directedEdge
orientation="-" xlink:href="#cd-E11" /><directedEdge><Edge
id="cd-E16"><directedNode orientation="-"><Node
id="cd-N11"/></directedNode><directedNode xlink:href="#cd-N12"
srsName="EPSG:4326"><segments><LineStringSegment><posList>47 6 47
id="cd-E14"><directedNode orientation="-" xlink:href="#cd-N10"
/><directedNode xlink:href="#cd-N11" /><curveProperty><Curve
srsName="EPSG:4326"><segments><LineStringSegment><posList>35 6 47
orientation="-" xlink:href="#cd-E18"
I'll check this one out. Could be just an order by issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3513>
