[postgis-tickets] [PostGIS] #3515: tiger_data not being backed up
PostGIS trac at osgeo.org
Fri Mar 25 20:41:59 PDT 2016
 Reporter:  robe            |      Owner:  robe
     Type:  defect          |     Status:  new
 Priority:  blocker         |  Milestone:  PostGIS 2.2.3
Component:  tiger geocoder  |    Version:  2.2.x
 Keywords:                  |
 Just discovered that tiger_data is not being backed up as part of a
 regular backup.  I thought the issue was because I specifically exclude it
 cause its the same and takes up so much space.
 Then I did a regular old backup and to my horror, the tiger_data schema
 did not get backed up.
 To fix I had to:
 ALTER EXTENSION postgis_tiger_gecoder DROP SCHEMA tiger_data;
 I think this started happening when I started automatically creating the
 tiger_data schema as part of create extension.  I never thought that if
 tiger_data is part of the extension it would mean the tables would be as
 well and not come backup.
 This personally seems like a bug to me, so I should probably verify
 upstream to be sure.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3515>
