[postgis-tickets] r14875 - #3119, Wrong documented behavior for ST_LengthSpheroid
Daniel Baston dbaston at gmail.com
Sun May 1 09:23:15 PDT 2016
Author: dbaston
Date: 2016-05-01 09:23:15 -0700 (Sun, 01 May 2016)
New Revision: 14875
   branches/2.1/doc/reference_measure.xml
   branches/2.1/install-sh
Modified: branches/2.1/doc/reference_measure.xml
--- branches/2.1/doc/reference_measure.xml	2016-05-01 16:23:08 UTC (rev 14874)
+++ branches/2.1/doc/reference_measure.xml	2016-05-01 16:23:15 UTC (rev 14875)
@@ -2843,7 +2843,7 @@
 	  <refnamediv>
 		<refname>ST_Length_Spheroid</refname>
-		<refpurpose>Calculates the 2D or 3D length of a linestring/multilinestring on an ellipsoid. This
+        <refpurpose>Calculates the 2D or 3D length/perimeter of a geometry on an ellipsoid. This
 			is useful if the coordinates of the geometry are in
 			longitude/latitude and a length is desired without reprojection.</refpurpose>
 	  </refnamediv>
@@ -2852,7 +2852,7 @@
 		<funcsynopsis>
 		  <funcprototype>
 			<funcdef>float <function>ST_Length_Spheroid</function></funcdef>
-			<paramdef><type>geometry </type> <parameter>a_linestring</parameter></paramdef>
+			<paramdef><type>geometry </type> <parameter>a_geometry</parameter></paramdef>
 			<paramdef><type>spheroid </type> <parameter>a_spheroid</parameter></paramdef>
 		  </funcprototype>
 		</funcsynopsis>
@@ -2861,23 +2861,19 @@
 	  <refsection>
 		<title>Description</title>
-		<para>Calculates the length of a geometry on an ellipsoid. This
+        <para>Calculates the length/perimeter of a geometry on an ellipsoid. This
 			The ellipsoid is a separate database type and can be constructed
 			as follows:</para>
-		<literallayout>SPHEROID[<NAME>,<SEMI-MAJOR
-		  AXIS>,<INVERSE FLATTENING>]</literallayout>
+		<literallayout>SPHEROID[<NAME>,<SEMI-MAJOR AXIS>,<INVERSE FLATTENING>]</literallayout>
 		<literallayout>SPHEROID["GRS_1980",6378137,298.257222101]</literallayout>
-		<note><para>Will return 0 for anything that is not a MULTILINESTRING or LINESTRING</para></note>
 		<para>&Z_support;</para>
 	  </refsection>
 	  <refsection>
 		<title>Examples</title>
@@ -2922,7 +2918,7 @@
 	  <refnamediv>
 		<refname>ST_Length2D_Spheroid</refname>
-		<refpurpose>Calculates the 2D length of a linestring/multilinestring on an ellipsoid. This
+        <refpurpose>Calculates the 2D length/perimeter of a geometry on an ellipsoid. This
 			longitude/latitude and a length is desired without reprojection.  </refpurpose>
 	  </refnamediv>
@@ -2931,7 +2927,7 @@
 		<funcsynopsis>
 		  <funcprototype>
 			<funcdef>float <function>ST_Length2D_Spheroid</function></funcdef>
 		  </funcprototype>
 		</funcsynopsis>
@@ -2946,12 +2942,9 @@
 			as follows:</para>
 		<note><para>This is much like <xref linkend="ST_Length_Spheroid" /> and <xref linkend="ST_3DLength_Spheroid" /> except it will throw away the Z coordinate in calculations.</para></note>
 	  </refsection>
Modified: branches/2.1/install-sh
--- branches/2.1/install-sh	2016-05-01 16:23:08 UTC (rev 14874)
+++ branches/2.1/install-sh	2016-05-01 16:23:15 UTC (rev 14875)
@@ -1,7 +1,7 @@
 #!/bin/sh
 # install - install a program, script, or datafile
-scriptversion=2013-12-25.23; # UTC
+scriptversion=2011-11-20.07; # UTC
 # This originates from X11R5 (mit/util/scripts/install.sh), which was
 # later released in X11R6 (xc/config/util/install.sh) with the
@@ -41,15 +41,19 @@
 # This script is compatible with the BSD install script, but was written
 # from scratch.
-tab='	'
 nl='
-IFS=" $tab$nl"
+IFS=" ""	$nl"
-# Set DOITPROG to "echo" to test this script.
+# set DOITPROG to echo to test this script
+# Don't use :- since 4.3BSD and earlier shells don't like it.
 doit=${DOITPROG-}
-doit_exec=${doit:-exec}
+if test -z "$doit"; then
+  doit_exec=exec
+else
+  doit_exec=$doit
+fi
 # Put in absolute file names if you don't have them in your path;
 # or use environment vars.
@@ -64,6 +68,17 @@
 rmprog=${RMPROG-rm}
 stripprog=${STRIPPROG-strip}
+posix_glob='?'
+initialize_posix_glob='
+  test "$posix_glob" != "?" || {
+    if (set -f) 2>/dev/null; then
+      posix_glob=
+    else
+      posix_glob=:
+    fi
 posix_mkdir=
 # Desired mode of installed file.
@@ -82,7 +97,7 @@
 dst_arg=
 copy_on_change=false
-is_target_a_directory=possibly
+no_target_directory=
 usage="\
 Usage: $0 [OPTION]... [-T] SRCFILE DSTFILE
@@ -122,57 +137,46 @@
     -d) dir_arg=true;;
     -g) chgrpcmd="$chgrpprog $2"
-        shift;;
+	shift;;
     --help) echo "$usage"; exit $?;;
     -m) mode=$2
-        case $mode in
-          *' '* | *"$tab"* | *"$nl"* | *'*'* | *'?'* | *'['*)
-            echo "$0: invalid mode: $mode" >&2
-            exit 1;;
-        esac
-        shift;;
+	case $mode in
+	    echo "$0: invalid mode: $mode" >&2
+	    exit 1;;
+	esac
+	shift;;
     -o) chowncmd="$chownprog $2"
-        shift;;
+	shift;;
     -s) stripcmd=$stripprog;;
-    -t)
-        is_target_a_directory=always
-        dst_arg=$2
-        # Protect names problematic for 'test' and other utilities.
-        case $dst_arg in
-          -* | [=\(\)!]) dst_arg=./$dst_arg;;
-        esac
-        shift;;
+    -t) dst_arg=$2
+	# Protect names problematic for 'test' and other utilities.
+	case $dst_arg in
+	  -* | [=\(\)!]) dst_arg=./$dst_arg;;
+	esac
+	shift;;
-    -T) is_target_a_directory=never;;
+    -T) no_target_directory=true;;
     --version) echo "$0 $scriptversion"; exit $?;;
-    --) shift
-        break;;
+    --)	shift
+	break;;
-    -*) echo "$0: invalid option: $1" >&2
-        exit 1;;
+    -*)	echo "$0: invalid option: $1" >&2
+	exit 1;;
     *)  break;;
   esac
   shift
 done
-# We allow the use of options -d and -T together, by making -d
-# take the precedence; this is for compatibility with GNU install.
-if test -n "$dir_arg"; then
-  if test -n "$dst_arg"; then
-    echo "$0: target directory not allowed when installing a directory." >&2
-    exit 1
-  fi
-fi
 if test $# -ne 0 && test -z "$dir_arg$dst_arg"; then
   # When -d is used, all remaining arguments are directories to create.
   # When -t is used, the destination is already specified.
@@ -204,15 +208,6 @@
 fi
 if test -z "$dir_arg"; then
-  if test $# -gt 1 || test "$is_target_a_directory" = always; then
-    if test ! -d "$dst_arg"; then
-      echo "$0: $dst_arg: Is not a directory." >&2
-      exit 1
-    fi
-  fi
-fi
-if test -z "$dir_arg"; then
   do_exit='(exit $ret); exit $ret'
   trap "ret=129; $do_exit" 1
   trap "ret=130; $do_exit" 2
@@ -228,16 +223,16 @@
     *[0-7])
       if test -z "$stripcmd"; then
-        u_plus_rw=
+	u_plus_rw=
       else
-        u_plus_rw='% 200'
+	u_plus_rw='% 200'
       fi
       cp_umask=`expr '(' 777 - $mode % 1000 ')' $u_plus_rw`;;
-        u_plus_rw=
+	u_plus_rw=
       else
-        u_plus_rw=,u+rw
+	u_plus_rw=,u+rw
       fi
       cp_umask=$mode$u_plus_rw;;
   esac
@@ -274,15 +269,41 @@
     # If destination is a directory, append the input filename; won't work
     # if double slashes aren't ignored.
     if test -d "$dst"; then
-      if test "$is_target_a_directory" = never; then
-        echo "$0: $dst_arg: Is a directory" >&2
-        exit 1
+      if test -n "$no_target_directory"; then
+	echo "$0: $dst_arg: Is a directory" >&2
+	exit 1
       fi
       dstdir=$dst
       dst=$dstdir/`basename "$src"`
       dstdir_status=0
     else
-      dstdir=`dirname "$dst"`
+      # Prefer dirname, but fall back on a substitute if dirname fails.
+      dstdir=`
+	(dirname "$dst") 2>/dev/null ||
+	expr X"$dst" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+	     X"$dst" : 'X\(//\)[^/]' \| \
+	     X"$dst" : 'X\(//\)$' \| \
+	     X"$dst" : 'X\(/\)' \| . 2>/dev/null ||
+	echo X"$dst" |
+	    sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
+		   s//\1/
+		   q
+		 /^X\(\/\/\)[^/].*/{
+		   s//\1/
+		   q
+		 /^X\(\/\/\)$/{
+		   s//\1/
+		   q
+		 /^X\(\/\).*/{
+		   s//\1/
+		   q
+		 s/.*/./; q'
       test -d "$dstdir"
       dstdir_status=$?
     fi
@@ -293,74 +314,74 @@
   if test $dstdir_status != 0; then
     case $posix_mkdir in
-        # Create intermediate dirs using mode 755 as modified by the umask.
-        # This is like FreeBSD 'install' as of 1997-10-28.
-        umask=`umask`
-        case $stripcmd.$umask in
-          # Optimize common cases.
-          *[2367][2367]) mkdir_umask=$umask;;
-          .*0[02][02] | .[02][02] | .[02]) mkdir_umask=22;;
+	# Create intermediate dirs using mode 755 as modified by the umask.
+	# This is like FreeBSD 'install' as of 1997-10-28.
+	umask=`umask`
+	case $stripcmd.$umask in
+	  # Optimize common cases.
+	  *[2367][2367]) mkdir_umask=$umask;;
+	  .*0[02][02] | .[02][02] | .[02]) mkdir_umask=22;;
-          *[0-7])
-            mkdir_umask=`expr $umask + 22 \
-              - $umask % 100 % 40 + $umask % 20 \
-              - $umask % 10 % 4 + $umask % 2
-          *) mkdir_umask=$umask,go-w;;
-        esac
+	  *[0-7])
+	    mkdir_umask=`expr $umask + 22 \
+	      - $umask % 100 % 40 + $umask % 20 \
+	      - $umask % 10 % 4 + $umask % 2
+	  *) mkdir_umask=$umask,go-w;;
+	esac
-        # With -d, create the new directory with the user-specified mode.
-        # Otherwise, rely on $mkdir_umask.
-        if test -n "$dir_arg"; then
-          mkdir_mode=-m$mode
-        else
-          mkdir_mode=
-        fi
+	# With -d, create the new directory with the user-specified mode.
+	# Otherwise, rely on $mkdir_umask.
+	if test -n "$dir_arg"; then
+	  mkdir_mode=-m$mode
+	else
+	  mkdir_mode=
+	fi
-        posix_mkdir=false
-        case $umask in
-          *[123567][0-7][0-7])
-            # POSIX mkdir -p sets u+wx bits regardless of umask, which
-            # is incompatible with FreeBSD 'install' when (umask & 300) != 0.
-            tmpdir=${TMPDIR-/tmp}/ins$RANDOM-$$
-            trap 'ret=$?; rmdir "$tmpdir/d" "$tmpdir" 2>/dev/null; exit $ret' 0
+	posix_mkdir=false
+	case $umask in
+	  *[123567][0-7][0-7])
+	    # POSIX mkdir -p sets u+wx bits regardless of umask, which
+	    # is incompatible with FreeBSD 'install' when (umask & 300) != 0.
+	    tmpdir=${TMPDIR-/tmp}/ins$RANDOM-$$
+	    trap 'ret=$?; rmdir "$tmpdir/d" "$tmpdir" 2>/dev/null; exit $ret' 0
-            if (umask $mkdir_umask &&
-                exec $mkdirprog $mkdir_mode -p -- "$tmpdir/d") >/dev/null 2>&1
-            then
-              if test -z "$dir_arg" || {
-                   # Check for POSIX incompatibilities with -m.
-                   # HP-UX 11.23 and IRIX 6.5 mkdir -m -p sets group- or
-                   # other-writable bit of parent directory when it shouldn't.
-                   # FreeBSD 6.1 mkdir -m -p sets mode of existing directory.
-                   ls_ld_tmpdir=`ls -ld "$tmpdir"`
-                   case $ls_ld_tmpdir in
-                     d????-?r-*) different_mode=700;;
-                     d????-?--*) different_mode=755;;
-                     *) false;;
-                   esac &&
-                   $mkdirprog -m$different_mode -p -- "$tmpdir" && {
-                     ls_ld_tmpdir_1=`ls -ld "$tmpdir"`
-                     test "$ls_ld_tmpdir" = "$ls_ld_tmpdir_1"
-              then posix_mkdir=:
-              fi
-              rmdir "$tmpdir/d" "$tmpdir"
-            else
-              # Remove any dirs left behind by ancient mkdir implementations.
-              rmdir ./$mkdir_mode ./-p ./-- 2>/dev/null
-            fi
-            trap '' 0;;
-        esac;;
+	    if (umask $mkdir_umask &&
+		exec $mkdirprog $mkdir_mode -p -- "$tmpdir/d") >/dev/null 2>&1
+	    then
+	      if test -z "$dir_arg" || {
+		   # Check for POSIX incompatibilities with -m.
+		   # HP-UX 11.23 and IRIX 6.5 mkdir -m -p sets group- or
+		   # other-writable bit of parent directory when it shouldn't.
+		   # FreeBSD 6.1 mkdir -m -p sets mode of existing directory.
+		   ls_ld_tmpdir=`ls -ld "$tmpdir"`
+		   case $ls_ld_tmpdir in
+		     d????-?r-*) different_mode=700;;
+		     d????-?--*) different_mode=755;;
+		     *) false;;
+		   esac &&
+		   $mkdirprog -m$different_mode -p -- "$tmpdir" && {
+		     ls_ld_tmpdir_1=`ls -ld "$tmpdir"`
+		     test "$ls_ld_tmpdir" = "$ls_ld_tmpdir_1"
+	      then posix_mkdir=:
+	      fi
+	      rmdir "$tmpdir/d" "$tmpdir"
+	    else
+	      # Remove any dirs left behind by ancient mkdir implementations.
+	      rmdir ./$mkdir_mode ./-p ./-- 2>/dev/null
+	    fi
+	    trap '' 0;;
+	esac;;
     esac
     if
       $posix_mkdir && (
-        umask $mkdir_umask &&
-        $doit_exec $mkdirprog $mkdir_mode -p -- "$dstdir"
+	umask $mkdir_umask &&
+	$doit_exec $mkdirprog $mkdir_mode -p -- "$dstdir"
     then :
     else
@@ -370,51 +391,53 @@
       # directory the slow way, step by step, checking for races as we go.
       case $dstdir in
-        /*) prefix='/';;
-        [-=\(\)!]*) prefix='./';;
-        *)  prefix='';;
+	/*) prefix='/';;
+	[-=\(\)!]*) prefix='./';;
+	*)  prefix='';;
       esac
+      eval "$initialize_posix_glob"
       oIFS=$IFS
       IFS=/
-      set -f
+      $posix_glob set -f
       set fnord $dstdir
       shift
-      set +f
+      $posix_glob set +f
       IFS=$oIFS
       prefixes=
       for d
       do
-        test X"$d" = X && continue
+	test X"$d" = X && continue
-        prefix=$prefix$d
-        if test -d "$prefix"; then
-          prefixes=
-        else
-          if $posix_mkdir; then
-            (umask=$mkdir_umask &&
-             $doit_exec $mkdirprog $mkdir_mode -p -- "$dstdir") && break
-            # Don't fail if two instances are running concurrently.
-            test -d "$prefix" || exit 1
-          else
-            case $prefix in
-              *\'*) qprefix=`echo "$prefix" | sed "s/'/'\\\\\\\\''/g"`;;
-              *) qprefix=$prefix;;
-            esac
-            prefixes="$prefixes '$qprefix'"
-          fi
-        fi
-        prefix=$prefix/
+	prefix=$prefix$d
+	if test -d "$prefix"; then
+	  prefixes=
+	else
+	  if $posix_mkdir; then
+	    (umask=$mkdir_umask &&
+	     $doit_exec $mkdirprog $mkdir_mode -p -- "$dstdir") && break
+	    # Don't fail if two instances are running concurrently.
+	    test -d "$prefix" || exit 1
+	  else
+	    case $prefix in
+	      *\'*) qprefix=`echo "$prefix" | sed "s/'/'\\\\\\\\''/g"`;;
+	      *) qprefix=$prefix;;
+	    esac
+	    prefixes="$prefixes '$qprefix'"
+	  fi
+	fi
+	prefix=$prefix/
       done
       if test -n "$prefixes"; then
-        (umask $mkdir_umask &&
-         eval "\$doit_exec \$mkdirprog $prefixes") ||
-          test -d "$dstdir" || exit 1
-        obsolete_mkdir_used=true
+	(umask $mkdir_umask &&
+	 eval "\$doit_exec \$mkdirprog $prefixes") ||
+	  test -d "$dstdir" || exit 1
+	obsolete_mkdir_used=true
       fi
     fi
   fi
@@ -449,12 +472,15 @@
     # If -C, don't bother to copy if it wouldn't change the file.
     if $copy_on_change &&
-       old=`LC_ALL=C ls -dlL "$dst"     2>/dev/null` &&
-       new=`LC_ALL=C ls -dlL "$dsttmp"  2>/dev/null` &&
-       set -f &&
+       old=`LC_ALL=C ls -dlL "$dst"	2>/dev/null` &&
+       new=`LC_ALL=C ls -dlL "$dsttmp"	2>/dev/null` &&
+       eval "$initialize_posix_glob" &&
+       $posix_glob set -f &&
        set X $old && old=:$2:$4:$5:$6 &&
        set X $new && new=:$2:$4:$5:$6 &&
-       set +f &&
+       $posix_glob set +f &&
        test "$old" = "$new" &&
        $cmpprog "$dst" "$dsttmp" >/dev/null 2>&1
     then
@@ -467,24 +493,24 @@
       # to itself, or perhaps because mv is so ancient that it does not
       # support -f.
-        # Now remove or move aside any old file at destination location.
-        # We try this two ways since rm can't unlink itself on some
-        # systems and the destination file might be busy for other
-        # reasons.  In this case, the final cleanup might fail but the new
-        # file should still install successfully.
-          test ! -f "$dst" ||
-          $doit $rmcmd -f "$dst" 2>/dev/null ||
-          { $doit $mvcmd -f "$dst" "$rmtmp" 2>/dev/null &&
-            { $doit $rmcmd -f "$rmtmp" 2>/dev/null; :; }
-          { echo "$0: cannot unlink or rename $dst" >&2
-            (exit 1); exit 1
+	# Now remove or move aside any old file at destination location.
+	# We try this two ways since rm can't unlink itself on some
+	# systems and the destination file might be busy for other
+	# reasons.  In this case, the final cleanup might fail but the new
+	# file should still install successfully.
+	  test ! -f "$dst" ||
+	  $doit $rmcmd -f "$dst" 2>/dev/null ||
+	  { $doit $mvcmd -f "$dst" "$rmtmp" 2>/dev/null &&
+	    { $doit $rmcmd -f "$rmtmp" 2>/dev/null; :; }
+	  { echo "$0: cannot unlink or rename $dst" >&2
+	    (exit 1); exit 1
-        # Now rename the file to the real destination.
-        $doit $mvcmd "$dsttmp" "$dst"
+	# Now rename the file to the real destination.
+	$doit $mvcmd "$dsttmp" "$dst"
     fi || exit 1
