[postgis-tickets] [PostGIS] #2362: Support building with CMake
trac at osgeo.org
Sun May 8 08:59:40 PDT 2016
Reporter: robe | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS Future
Component: build/upgrade/install | Version: trunk
Resolution: | Keywords:
Changes (by Bishop):
* cc: Bishop (added)
Comment:
Replying to [comment:5 robe]:
> It's about time I upgraded anyway so not a big deal. Just wondering if
it would be an issue on other platforms. I have cmake 2.8.11 and first
message I get out of the gate is
Yes, you right, the minimal CMake version set to 2.8.12 as this version is
default on most Linux distros. As CMake now 3.x it seems to me 2.8.12 is
OK. But 2.8.11 or less may be tested.
About libGEOS - I noted that on Windows not tested - this mean mingw and
cygwin too.
Also there are some CMake keys to get lost dependencies - i.e.
-DWITH_GEOS_EXTERNAL=ON (the -DWITH_GEOS=ON mast be set too). In such case
the latest libGEOS will be downloaded and build.
Anyhow patch for GEOS detection under mingw is welcome.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2362#comment:8>
