[postgis-tickets] r14885 - Closes #3514 zipcode penalty switch
Regina Obe
lr at pcorp.us
Mon May 9 01:26:31 PDT 2016
Author: robe
Date: 2016-05-09 01:26:31 -0700 (Mon, 09 May 2016)
New Revision: 14885
trunk/extras/tiger_geocoder/geocode/geocode_address.sql
trunk/extras/tiger_geocoder/geocode_settings.sql
fix casting issue introduced in r14850
Modified: trunk/extras/tiger_geocoder/geocode/geocode_address.sql
--- trunk/extras/tiger_geocoder/geocode/geocode_address.sql 2016-05-04 22:02:48 UTC (rev 14884)
+++ trunk/extras/tiger_geocoder/geocode/geocode_address.sql 2016-05-09 08:26:31 UTC (rev 14885)
@@ -14,6 +14,7 @@
var_restrict_geom geometry := NULL;
var_bfilter text := null;
var_bestrating integer := NULL;
+ var_zip_penalty numeric := get_geocode_setting('zip_penalty')::numeric*1.00;
BEGIN
IF parsed.streetName IS NULL THEN
-- A street name must be given. Think about it.
@@ -90,7 +91,7 @@
stmt := 'WITH a AS
( SELECT *
FROM (SELECT f.*, ad.side, ad.zip, ad.fromhn, ad.tohn,
- RANK() OVER(ORDER BY ' || CASE WHEN parsed.zip > '' THEN ' diff_zip(ad.zip,$7) + ' ELSE '' END
+ RANK() OVER(ORDER BY ' || CASE WHEN parsed.zip > '' THEN ' diff_zip(ad.zip,$7)*$11 + ' ELSE '' END
||' CASE WHEN lower(f.name) = lower($2) THEN 0 ELSE levenshtein_ignore_case(f.name, lower($2) ) END +
levenshtein_ignore_case(f.fullname, lower($2 || '' '' || COALESCE($4,'''')) )
+ CASE WHEN (greatest_hn(ad.fromhn,ad.tohn) % 2)::integer = ($1 % 2)::integer THEN 0 ELSE 1 END
@@ -120,10 +121,10 @@
|| ' sub.zip as zip,'
|| ' interpolate_from_address($1, sub.fromhn,'
|| ' sub.tohn, sub.the_geom, sub.side) as address_geom,'
- || ' sub.sub_rating + '
- || CASE WHEN parsed.zip > '' THEN ' least(coalesce(diff_zip($7 , sub.zip),0), 10)::integer '
+ || ' (sub.sub_rating + '
+ || CASE WHEN parsed.zip > '' THEN ' least(coalesce(diff_zip($7 , sub.zip),0), 20)*$11 '
ELSE '1' END::text
- || ' + coalesce(levenshtein_ignore_case($3, sub.place),5)'
+ || ' + coalesce(levenshtein_ignore_case($3, sub.place),5) )::integer'
|| ' as sub_rating,'
|| ' sub.exact_address as exact_address, sub.tohn, sub.fromhn '
|| ' FROM ('
@@ -146,8 +147,8 @@
|| '(least_hn($1::text,least_hn(b.fromhn,b.tohn)::text)::numeric /'
|| ' (greatest(1,greatest_hn($1::text,greatest_hn(b.fromhn,b.tohn)::text))) )'
|| ') * 5)::integer + 5'
- || ' END'
- || ' as sub_rating,$1::integer >= least_hn(b.fromhn,b.tohn) '
+ || ' END::integer'
+ || ' AS sub_rating,$1::integer >= least_hn(b.fromhn,b.tohn) '
|| ' AND $1::integer <= greatest_hn(b.fromhn,b.tohn) '
|| ' AND ($1 % 2)::numeric::integer = (to_number(b.fromhn,''99999999'') % 2)'
|| ' as exact_address, b.name, b.prequalabr, b.pretypabrv, b.tfidr, b.tfidl, b.the_geom, b.place '
@@ -180,9 +181,9 @@
IF var_debug THEN
RAISE NOTICE 'stmt: %',
- replace(replace( replace(
+ replace( replace( replace(
replace(
- replace(replace( replace(replace(replace(replace(stmt, '$10', quote_nullable(in_statefp) ), '$2',quote_nullable(parsed.streetName)),'$3',
+ replace(replace( replace(replace(replace(replace( replace(stmt,'$11', var_zip_penalty::text), '$10', quote_nullable(in_statefp) ), '$2',quote_nullable(parsed.streetName)),'$3',
quote_nullable(parsed.location)), '$4', quote_nullable(parsed.streetTypeAbbrev) ),
'$5', quote_nullable(parsed.preDirAbbrev) ),
'$6', quote_nullable(parsed.postDirAbbrev) ),
@@ -193,7 +194,7 @@
--RAISE NOTICE 'EXECUTE query_base_geo(%,%,%,%,%,%,%,%,%); ', parsed.address,quote_nullable(parsed.streetName), quote_nullable(parsed.location), quote_nullable(parsed.streetTypeAbbrev), quote_nullable(parsed.preDirAbbrev), quote_nullable(parsed.postDirAbbrev), quote_nullable(parsed.zip), quote_nullable(var_restrict_geom::text), quote_nullable(zip_info.zip);
--RAISE NOTICE 'DEALLOCATE query_base_geo;';
END IF;
- FOR results IN EXECUTE stmt USING parsed.address,parsed.streetName, parsed.location, parsed.streetTypeAbbrev, parsed.preDirAbbrev, parsed.postDirAbbrev, parsed.zip, var_restrict_geom, zip_info.zip, in_statefp LOOP
+ FOR results IN EXECUTE stmt USING parsed.address,parsed.streetName, parsed.location, parsed.streetTypeAbbrev, parsed.preDirAbbrev, parsed.postDirAbbrev, parsed.zip, var_restrict_geom, zip_info.zip, in_statefp, var_zip_penalty LOOP
-- If we found a match with an exact street, then don't bother
-- trying to do non-exact matches
@@ -217,7 +218,7 @@
ADDY.parsed := TRUE;
GEOMOUT := results.address_geom;
- RATING := results.sub_rating;
+ RATING := results.sub_rating::integer;
var_n := var_n + 1;
IF var_bestrating IS NULL THEN
@@ -260,7 +261,7 @@
FROM zip_state WHERE zip_state.zip = $2
AND (' || quote_nullable(in_statefp) || ' IS NULL OR zip_state.statefp = ' || quote_nullable(in_statefp) || ')
' || COALESCE(' AND zip_state.zip IN(' || var_bfilter || ')', '') ||
- ' UNION SELECT zip_state_loc.statefp,zip_state_loc.place As location,false As exact, array_agg(zip_state_loc.zip) AS zip,1 + abs(COALESCE(diff_zip(max(zip), $2),0) - COALESCE(diff_zip(min(zip), $2),0)) As pref
+ ' UNION SELECT zip_state_loc.statefp,zip_state_loc.place As location,false As exact, array_agg(zip_state_loc.zip) AS zip,1 + abs(COALESCE(diff_zip(max(zip), $2),0) - COALESCE(diff_zip(min(zip), $2),0))*$3 As pref
FROM zip_state_loc
WHERE zip_state_loc.statefp = ' || quote_nullable(in_statefp) || '
AND lower($1) = lower(zip_state_loc.place) ' || COALESCE(' AND zip_state_loc.zip IN(' || var_bfilter || ')', '') ||
@@ -301,7 +302,7 @@
--JOIN (VALUES (true),(false)) as b(exact) on TRUE
WHERE statefp IS NOT NULL
GROUP BY statefp,location,zip,exact, pref ORDER BY exact desc, pref, zip **/
- FOR zip_info IN EXECUTE var_sql USING parsed.location, parsed.zip LOOP
+ FOR zip_info IN EXECUTE var_sql USING parsed.location, parsed.zip, var_zip_penalty LOOP
-- For zip distance metric we consider both the distance of zip based on numeric as well aa levenshtein
-- We use the prequalabr (these are like Old, that may or may not appear in front of the street name)
-- We also treat pretypabr as fetype since in normalize we treat these as streetypes and highways usually have the type here
@@ -316,10 +317,10 @@
|| ' sub.zip as zip,'
|| ' sub.tohn, e.the_geom, sub.side) as address_geom,'
- || CASE WHEN parsed.zip > '' THEN ' least((coalesce(diff_zip($7 , sub.zip),0) *1.00/2)::integer, coalesce(levenshtein_ignore_case($7, sub.zip),0) ) '
+ || CASE WHEN parsed.zip > '' THEN ' least((coalesce(diff_zip($7 , sub.zip),0) *$9)::integer, coalesce(levenshtein_ignore_case($7, sub.zip)*$9,0) ) '
ELSE '3' END::text
- || ' + coalesce(least(levenshtein_ignore_case($3, coalesce(p.name,zip.city,cs.name,co.name)), levenshtein_ignore_case($3, coalesce(cs.name,co.name))),5)'
+ || ' + coalesce(least(levenshtein_ignore_case($3, coalesce(p.name,zip.city,cs.name,co.name)), levenshtein_ignore_case($3, coalesce(cs.name,co.name))),5) )::integer'
|| ' as sub_rating,'
|| ' sub.exact_address as exact_address '
|| ' FROM ('
@@ -356,7 +357,7 @@
ELSE ' AND ( soundex($2) = soundex(a.name) OR ( (length($2) > 15 or (length($2) > 7 AND a.prequalabr > '''') ) AND lower(a.fullname) LIKE lower(substring($2,1,15)) || ''%'' ) OR numeric_streets_equal($2, a.name) ) '
END
|| ' ORDER BY 11'
- || ' LIMIT 20'
+ || ' LIMIT 200'
|| ' ) AS sub'
|| ' JOIN tiger.edges e ON (' || quote_literal(zip_info.statefp) || ' = e.statefp AND sub.tlid = e.tlid AND e.mtfcc LIKE ''S%'' '
|| CASE WHEN var_restrict_geom IS NOT NULL THEN ' AND ST_Intersects(e.the_geom, $8) ' ELSE '' END || ') '
@@ -373,8 +374,8 @@
IF var_debug THEN
RAISE NOTICE '%', stmt;
- RAISE NOTICE 'PREPARE query_base_geo(integer, varchar,varchar,varchar,varchar,varchar,varchar,geometry) As %', stmt;
- RAISE NOTICE 'EXECUTE query_base_geo(%,%,%,%,%,%,%,%); ', parsed.address,quote_nullable(parsed.streetName), quote_nullable(parsed.location), quote_nullable(parsed.streetTypeAbbrev), quote_nullable(parsed.preDirAbbrev), quote_nullable(parsed.postDirAbbrev), quote_nullable(parsed.zip), quote_nullable(var_restrict_geom::text);
+ RAISE NOTICE 'PREPARE query_base_geo(integer, varchar,varchar,varchar,varchar,varchar,varchar,geometry,numeric) As %', stmt;
+ RAISE NOTICE 'EXECUTE query_base_geo(%,%,%,%,%,%,%,%,%); ', parsed.address,quote_nullable(parsed.streetName), quote_nullable(parsed.location), quote_nullable(parsed.streetTypeAbbrev), quote_nullable(parsed.preDirAbbrev), quote_nullable(parsed.postDirAbbrev), quote_nullable(parsed.zip), quote_nullable(var_restrict_geom::text), quote_nullable(var_zip_penalty);
END IF;
-- If we got an exact street match then when we hit the non-exact
@@ -383,7 +384,7 @@
RETURN;
END IF;
- FOR results IN EXECUTE stmt USING parsed.address,parsed.streetName, parsed.location, parsed.streetTypeAbbrev, parsed.preDirAbbrev, parsed.postDirAbbrev, parsed.zip, var_restrict_geom LOOP
+ FOR results IN EXECUTE stmt USING parsed.address,parsed.streetName, parsed.location, parsed.streetTypeAbbrev, parsed.preDirAbbrev, parsed.postDirAbbrev, parsed.zip, var_restrict_geom, var_zip_penalty LOOP
@@ -392,7 +393,7 @@
END IF;
IF results.exact_address THEN
- ADDY.address := substring(parsed.address FROM '[0-9]+')::integer;
+ ADDY.address := substring(parsed.address::text FROM '[0-9]+')::integer;
ELSE
ADDY.address := NULL;
END IF;
@@ -407,7 +408,7 @@
var_n := var_n + 1;
-- If our ratings go above 99 exit because its a really bad match
Modified: trunk/extras/tiger_geocoder/geocode_settings.sql
--- trunk/extras/tiger_geocoder/geocode_settings.sql 2016-05-04 22:02:48 UTC (rev 14884)
+++ trunk/extras/tiger_geocoder/geocode_settings.sql 2016-05-09 08:26:31 UTC (rev 14885)
@@ -38,6 +38,7 @@
, ('debug_reverse_geocode', 'false', 'boolean','debug', 'if true, outputs debug information in notice log such as queries and intermediate expressions when reverse_geocode')
, ('reverse_geocode_numbered_roads', '0', 'integer','rating', 'For state and county highways, 0 - no preference in name, 1 - prefer the numbered highway name, 2 - prefer local state/county name')
, ('use_pagc_address_parser', 'false', 'boolean','normalize', 'If set to true, will try to use the address_standardizer extension (via pagc_normalize_address) instead of tiger normalize_address built on')
+ , ('zip_penalty', '2', 'numeric','rating', 'As input to rating will add (ref_zip - tar_zip)*zip_penalty where ref_zip is input address and tar_zip is a target address candidate')
) f(name,setting,unit,category,short_desc);
-- delete entries that are the same as default values
