[postgis-tickets] [PostGIS] #3548: Slow queries with ST_DWithin and geography columns
trac at osgeo.org
Mon May 9 09:53:04 PDT 2016
Reporter: rdallasgray | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.3
Component: postgis | Version: 2.1.x
Keywords: ST_DWithin geography |
We noticed that a query to find points within a given distance of a line
was running slowly. The points have SRID 4326 and are recorded with an
indexed geography column.
The culprit appears to be the filter step where `_st_dwithin` is run
against each of the records returned by the index.
We were able to work around the issue by introducing a second ST_DWithin
condition which runs against an indexed geometry column (again SRID 4326).
We set the distance parameter for this in a rough conversion of metres to
degrees, allowing a large buffer to ensure we include all candidate
points. This narrowed the field sufficiently and the query is now ~300%
faster.
Interestingly, the order of the two ST_DWithin queries matters. If we run
the geographic query first, we have poor performance. If we run the
geometric query first, we have the better performance.
Attached are redacted queries and explain results.
=== QUERY 1 ===
SELECT COUNT(*) FROM "locations"
WHERE (ST_DWithin(
ST_SetSRID(ST_MakeLine(
ARRAY[
ST_MakePoint(2.1736, 41.38518) <... redacted, approx 200 points>
ST_MakePoint(73.31681999999995, 55.05574999999999)
, 4326)::geography,
locations.geog,
5000,
false
=== EXPLAIN 1 ===
Aggregate (cost=2.76..2.77 rows=1 width=0) (actual
time=6501.755..6501.757 rows=1 loops=1)
Buffers: shared hit=15542
-> Index Scan using index_locations_on_geog on locations
(cost=0.28..2.76 rows=1 width=0) (actual time=8.016..6499.419 rows=1121
loops=1)
Index Cond: (geog && '01<...>40'::geography)
Filter: (('01<...>40'::geography && _st_expand(geog, 5000::double
precision)) AND _st_dwithin('01<...>40'::geography, geog, 5000::double
precision, false))
Rows Removed by Filter: 19213
Total runtime: 6502.081 ms
=== QUERY 2 ===
WHERE (ST_DWithin(
ARRAY[
, 4326)::geography,
locations.geog,
5000,
false
AND (ST_DWithin(
ARRAY[
, 4326),
locations.geom,
0.26
=== EXPLAIN 2 ===
Aggregate (cost=3.02..3.02 rows=1 width=0) (actual
time=5976.269..5976.270 rows=1 loops=1)
Buffers: shared hit=15468
(cost=0.28..3.01 rows=1 width=0) (actual time=5.942..5973.619 rows=1121
loops=1)
Filter: ((geom &&
'0103000020E6100000010000000500000075029A081B9EFE3F800EF3E50590444075029A081B9EFE3F8FC151F2EA484C406DEB6E9EEA6452408FC151F2EA484C406DEB6E9EEA645240800EF3E50590444075029A081B9EFE3F800EF3E505904440'::geometry)
AND ('01<...>40'::geography && _st_expand(geog, 5000::double precision))
AND ('01<...>40'::geometry && st_expand(geom, 0.26::double precision)) AND
_st_dwithin('01<...>40'::geography, geog, 5000::double precision, false)
AND _st_dwithin('01<...>40'::geometry, geom, 0.26::double precision))
Total runtime: 5976.354 ms
=== QUERY 3 ===
WHERE (ST_DWithin(
ARRAY[
, 4326),
locations.geom,
0.26
AND (ST_DWithin(
ARRAY[
, 4326)::geography,
locations.geog,
5000,
false
=== EXPLAIN 3 ===
time=1308.285..1308.287 rows=1 loops=1)
(cost=0.28..3.01 rows=1 width=0) (actual time=1.917..1306.076 rows=1121
loops=1)
Index Cond: (geog && '01...40'::geography)
Filter: ((geom &&
AND ('01...40'::geometry && st_expand(geom, 0.26::double precision)) AND
('01...40'::geography && _st_expand(geog, 5000::double precision)) AND
_st_dwithin('01...40'::geometry, geom, 0.26::double precision) AND
_st_dwithin('01...40'::geography, geog, 5000::double precision, false))
Total runtime: 1308.386 ms
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3548>
